Old 07-May-2009, 17:05   #1
zhed44 zhed44 is offline
zhed44's Avatar
Mood: YELLOW!!!
Question 748R Rough Running at Low Revs - What Chip is This?
Although I've had the Supersonic Canary for over 4 months now, due to having crashed it at more or less the first bend I encountered after buying it, today is the first time I've actually ridden it on anything other than a motorway.
Low speed corners and small roundabouts are a bit of a nightmare because the throttle response it awful. It doesn't pick up instantly, and when it does pick-up, it coughs, splutters and generally makes life really awkward.
I know the 748Rs are known for this sort of thing, and that it can be fixed with an Ultimap chip, so I just thought I'd check that there wasn't one already installed (I had one fitted on my 996S, but I can't remember what it looked like) and also check that the chip is correct for the bike and exhaust set-up that I am running.
The bike is a 2002 748R running a 50mm Termi half-system.
Here's a pic of the chip:
Old 07-May-2009, 17:44   #2
Looks like the OE chip for the open pipes. Defo not FIM.
Old 07-May-2009, 17:53   #3
Ducati ECU (Fuel Chip) Application List
Taken from Ducati SBK Catalogue 2003
(old ECU codes are shown in brackets from 2001 catalogue)
96502394C (08054/1) - 916 Monoposto '94, silencers Racing
965013AAA (08054/3) - 916 Biposto silencers Racing
965015AAA (08054/11) - 996 Racing silencers
965014AAA (08054/6) - 748 Twin-seat silencers Racing
965024AAA (08054/15) - 748R Silencers Racing
96502694C (08054/19) - 916 Monoposto '94, silencers Ø 50
965027AAA (08054/20) - 916 Biposto silencers Ø 50
965025AAA (08054/22) - 996 Silencers Ø 50
96506501B (n/a) - 996S Silencers Racing Ø 50
965028AAA (08054/17) - 748 Biposto silencers Ø 50
965029AAA (08054/18) - 748SPS Silencers Ø 50
965030AAA (08054/16) - 748R Silencers Ø 50
96503394C (08054/2) - 916 Monoposto '94, complete assembly Ø 50
96503494C (08054/4) - 916 Biposto complete assembly Ø 50
965035AAA (08054/5) - 916SP Complete assembly Ø 50
965031AAA (08054/14) - 996 Complete assembly Ø 50
965032AAA (08054/26) - 996SPS/916SPS Complete assembly Ø 50
965036AAA (08054/7) - 748 Biposto complete assembly Ø 50
965044AAA (08054/8) - 748SPS Complete assembly Ø 50
965037AAA (08054/25) - 748R Complete assembly Ø 50
965038AAA (08054/23) - 996 Complete assembly Ø 52
965040AAA (08054/21) - 916 Biposto complete assembly Ø 52
965035AAA (08054/5) - 916 SP Complete assembly Ø 52
965039AAA (08054/24) - 996SPS/916SPS Complete assembly Ø 52
Ducati Sporting Club
http://www.DucatiSportingClub.com/
Old 07-May-2009, 18:54   #4
Just checked my chip that I took out of my 748R 2000 that had 50mm termi's on before I changed it for a FIM chip from Nelly at Cornerspeed.
748R 2000
077-1
So mine is different, so pass I guess.
Old 07-May-2009, 19:29   #5
Gaz 748's Avatar
I have an FIM Ultimap chip in mine, its great, get slght hunting at 4,000 rpm apart for that its pefect, would recomend one. Pro Twins in Godstone sell them.
I have a 02 748R with 50mmTermi`s
748R - Less is more !
Old 07-May-2009, 20:57   #6
zhed44's Avatar
Mood: YELLOW!!!
Thumbs up
Thanks for the replies everyone, they've been really helpful.
Looks like "FIM chip" is going to be added to the ever expanding "To Do" list then....
Originally Posted by Gaz 748
I have an FIM Ultimap chip.... Pro Twins in Godstone sell them.
Are they 'plug and play', or do they need to be set up by a professional? My ex-996S came with an FIM already installed, so I don't know anything about the fitting process.
Old 07-May-2009, 21:14   #7
Gaz 748's Avatar
Just plug in and play, i would say they are 95% ready to go, you can set them
up on a dyno if you want it spot on. Moto Rapido can do this for you. Its just an eprom, remove old one and fit new one, make sure its in the right way around,there is a cutout on one side, just change it like for like.
Old 07-May-2009, 21:24   #8
zhed44's Avatar
Mood: YELLOW!!!
Thanks Gaz. Much appreciated
Old 07-May-2009, 21:31   #9
zhed44's Avatar
Mood: YELLOW!!!
It looks like I may have the wrong brain installled (story of my life).
The same chip as mine is on eBay advertised as "748R chip for 45mm road cans"
http://cgi.ebay.co.uk/Ducati-748R-St...3A1%7C294%3A50
The same seller also has a chip for "748R 50mm race cans", so subject to clarification that this is suitable for a 50mm half-system, as it's a lot cheaper than a FIM chip, I may give it a go.
http://cgi.ebay.co.uk/Ducati-748R-Pe...3A1%7C294%3A50
Any thoughts?
Old 07-May-2009, 21:38   #10
Gaz 748's Avatar
If its cheap, go for it. I know the FIM chips are expensive, but i think the best.
p.s. i get 140 miles before the fuel light comes on.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:54.
