Old 19-May-2009, 19:45
phil_h's Avatar
phil_h phil_h is offline
Cylinder stud help please
My 851 engine rebuild saga continues ...
So there I am happily fitting the new rings that have finally arrived after months of waiting, and I realise that I've not put the cylinder studs back in yet.
No probs I think ... then realise that I never bought a stud puller to use to torque them up properly (one of the reasons studs fail is cause they havnt been torqued properly).
No probs you think too, just go and buy a stud thingy ... except I have, and they dont fit WAISTED studs
So, how do you properly torque up waisted studs ?
Please ?
(I have 6 ducati manuals and none of them even mention cylinder studs !)
Old 19-May-2009, 20:16
Scooter916's Avatar
Mood: Hmmm Conference season
Phill not somthing that I have ever come across, Studs having to be torqued must be a ducati thang.
But if I had to do it I would tighten a couple of nuts against eachother and torque using the top nut.
Glyn
Old 19-May-2009, 22:22
Glyn
ditto that
Old 19-May-2009, 22:23
Glyn
Yep, I've got to do that on the 'zorst manifold studs and that's the way I'm going to torque them
___________^
Old 21-May-2009, 23:58
burtsp5's Avatar
DSC Member burtsp5 burtsp5 is offline
Mood: Was broke, but getting better!!:)
Hi Jools, see you're having a debate re. your studs, locking nuts is about the only way but, if just be careful that the studs are not bottoming out so all you're going to do is force them into the casting and secondly,if the studs are just part threaded without a step in them you're going to just pull them in deeper. I'm not sue what the studs are like on your engine.
Finally, are they tightened with an actual torge figure or an angle x2 or 3 or degree figure,?
umm i'd give Geoff Baines at Baines racing at Silverstone a call as he did my engine some years back.
Trust alls well.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:55.
