Old 22-May-2009, 18:29   #1
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
sorry sprockets AGAIN
Hello
I have just bought a Regina 94 link chain.
and was thinking about sprockets.
At present on my 748 I have a 14 tooth on the front and 38 on the rear (sprocket carrier)
But as the bike is now an 853 would you suggest keeping this setup?
I understand you can swap and change, but I just need a starting point
as I intend to look into this in more detail at a later date.
2 and a bit weeks to build my bike
regards
TopiToo
Old 22-May-2009, 18:44   #2
RickyX RickyX is offline
RickyX's Avatar
Got 14/39 on my 916SPS so I'm sure things will be great on your 853.
Enjoy!
R
Old 22-May-2009, 18:54   #3
Steve if you make it to Benson I could bring some sprockets along for you to try
Old 22-May-2009, 19:41   #4
The 916SPS has a different primary gear ratio than the 748 so the above sprocket suggestion is inappropriate.
For 853's I recommend a 15/38, 96-link setup.
(Don't forget to measure your rear ride height first so you can reset it.)
Old 22-May-2009, 23:03   #5
Bikes: 748ish . .
Hello Shazaam
Dam'it I knew it would be a different chain link,
Nelly is running 15/38 if I am right.
Ok I will see if I can get back to 96 links
Thanks Shazaam
regards
TopiToo
Old 22-May-2009, 23:06   #6
Bikes: 748ish . .
Hello Skidlids
Many thanks mate for the offer, but my problem is I need a MOT
as I need toget some miles in to bed down the piston rings
TopiToo
Old 22-May-2009, 23:06   #7
steve, I have a set of std sprockets which I think is a 15/38 or 39 rear your welcome to have if you want them, bit rusty probably but some life in them
Old 22-May-2009, 23:16   #8
Bikes: 748ish . .
Hello Bradders
Thanks mate for the offer I may be intrested in the front, *(15)
I just need to get this bloody MOT done so I can run in the bike
so I can do an oil change . . . .
I have booked a few days off next week and hope to have the engine home
to paint Tues/Weds then it's mad rush time if it comes together bloody fantastic and thanks to one and all.
if not no sweat as I need to make sure I am happy and safe to ride the bike
regards
TopiToo
Old 22-May-2009, 23:20   #9
Probably 525 size and Steve's new chain is 520
The smallest renthal quick change sprocket I have in 520 is a 37T
I have a brand new 520 alloy AFAM 35T, its the type you have to fit the cush drives into
14/35 would be nigh on the same as 15/38 but without te need for the longer chain £30 to you if your interested
Old 22-May-2009, 23:24   #10
The AFAM is just like this one only his is cheaper so if its a 520 it may be worth a bid
http://cgi.ebay.co.uk/DUCATI-748-916...3A1%7C294%3A50
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:53.
