Old 25-May-2009, 21:48   #1
Sharpy G Sharpy G is offline
Bikes: 749R 2004
Sharpy G's Avatar
Question 749R fuel tank breather conundrum - can you help ?
Hi all
so, bit of a weird thing with the fuel tank breather setup on the 749R tank
details:
Corse billet cap has no breather
Tank blanking plug removed, fitted with threaded adaptor with a black plastic inline breather valve that will allow air in but not out and clear tube routed to front of fairing
with standard cap removed it leaves 2 open holes in the tank cap recess, one threaded one not (the non threaded one, I believe vented thro the standard cap via a rubber o ring and something in the cap frame)
so as I had the tank top valve open I blanked off the threaded one with a bolt and the open hole with a rubber plug
All looked good, however on a run out today, when I went to fill up with gas after around 10mins riding, when I open the twist lock cap it sprayed fuel out of it as if under pressure ?????!!!!!
same again up at Boxhill, however I only released the cap after fuel was being pushed up the pipe and the wrong way thro the valve into the pipe and down into the fairing !!!!!!!
anyone have any ideas please ?
or a diagram of the 749R race bike breather setup ?
cheers
Sharpy
Old 25-May-2009, 23:33   #2
bolds bolds is offline
Originally Posted by Sharpy G
Hi all
details:
cheers
Sharpy
Race set up
Old 26-May-2009, 00:24   #3
Bikes: 749R 2004
Sharpy G's Avatar
Thumbs up
Originally Posted by bolds
Race set up
thanks 'bolds' what a star !!!
Old 28-May-2009, 09:45   #4
Sounds like the breather valve might be faulty(no.4 in pdf) or partially blocked.
Not sure about blanking off that threaded hole either,.....is'nt that part of the tank overflow system?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:53.
