Old 30-May-2009, 15:44   #1
greggyboy greggyboy is offline
Db Killers
Hi all, trying to remove my db killers on my s2r termi's. Is it just a matter of pulling them out or is there more to it. I have tried pulling them out but they will not move.
I would be grateful for any tips.
regards
greg.
Old 02-Jun-2009, 21:11   #2
You did take the bolt/rivit out first,did you?
Seriously tho,those Termig baffles are notoriously difficult to remove.Sometimes its better to remove the can and knock them out from the other end.
Old 02-Dec-2009, 21:32   #3
DSC Member 916Neil 916Neil is offline
916Neil's Avatar
Mood: Waiting for summer
Without removing the cans - Fit some mole grips to the long end of an allen key. Hook the short end of the allen key around the vertical bar on the baffle. Then whack the mole grips with a hammer. Worked on mine. Seems that the short sharp shock does the trick better than trying to grip the baffle with pliers and pulling it out.
Regards
Neil
Live each day as if it's your last - one day you will surely be right
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:14.
