Old 03-Jun-2004, 15:29   #1
AgentOrange AgentOrange is offline
I know your not supposed to but......
OK, so most of the time I use only the front brakes but there are quite a few occassions where the back brake (and back brake only) is useful. The problem with my ST2 is that no matter how much pressure I apply it seems to have little or no effect. It has been like this from new. I do go to quite a few rallies and this usually means traveling down a muddy or gravel path which can cause some concern.
The brake set up is standard i.e. original hoses so is there any upgrade people can suggest?
Old 03-Jun-2004, 15:37   #2
I think thats how they are to be honest. I was at some trafic lights the other day with Lynn on the back. Its was a slight hill and the back brake wouldnt hold us still even when we were stationary.
Old 03-Jun-2004, 16:07   #3
ali ali is offline
ali's Avatar
Mood: Damp
There's quite a lot you can do to uprate back brakes, but not much that will have a noticable effect! For more bite I'd recommend new pads, but I'm not to sure which of the current lot will give the best results. I'm sure someone else on this board will know.
I use the back brake quite a lot, mostly for dragging into corners, allowing the forks to rebound so your steering's unaffected mid-corner. Unfortunately I've currently got sintered pads on the back so it sounds like there's gravel stuck in the back brake...... nasty.
Cheers,
Ali
Old 03-Jun-2004, 19:38   #4
Monty's Avatar
When I got my ST4S I complained at the first service that the back brake didn't work-the mechanic rode round the car park and locked the wheel to prove it did-I still think it's crap mind and that's after 22,000 miles.
John
Old 03-Jun-2004, 21:47   #5
John W John W is offline
John W's Avatar
I was using my rear brake so hard on our last trip that I could feel the ABS pulsing the pedal, so it does work !
Old 03-Jun-2004, 22:51   #6
kwikbitch's Avatar
Back brake....??? Ducati? Are you avvin a LARF!!!!!!!!!
Mines the same...from new...Sigh
Old 03-Jun-2004, 23:13   #7
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
Get a wavy rear disc and Bendix pads...you can lock the back up at will!
( Got mine from Neil at Cornerspeed of course! )
Works for me......
Old 03-Jun-2004, 23:27   #8
paulmort paulmort is offline
Mood: Blooo Duke gets red heads
Brakes are the killer of speed
Pronto article by Andy I of CSS says it all
bestest
mort
oh, btw dont use the rear at all except at tfc lights uphill
Old 03-Jun-2004, 23:42   #9
I haven't got a back brake - I think????uzz led:
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:18.
