General Motorcycles only
Old 04-Jun-2009, 19:22   #1
eddie 851 eddie 851 is offline
stupidest question ever ??
I had a fuel injector problem so I remove both injectors and had one clean but had to replace the other one as it had seized. This has taken the best part of two weeks; I’ve not the best of memory so in the meantime I’ve forgotten which cylinder is which. So the question is:-
Which cylinder is #1 and which is #2 ??????
(oh by the way it’s off a 91 851)
cheers rob
Old 04-Jun-2009, 19:52   #2
Check the cable on the plugs for the injectors.
They should be marked with an "O" for "Orizzontale" - that's Horizontal in English - and the other will be marked with a "V" for "Verticale" - which is Vertical.
That tells you which connector goes to which cylinder
Old 04-Jun-2009, 20:18   #3
ive looked at my cables but theyre marked 1 and 2 not O and V.
Thanks for the reply but im still stuck if anybodys got any answers ill be more than greatful.
cheers rob
Old 04-Jun-2009, 21:07   #4
Jasper Jasper is offline
Jasper's Avatar
I know it's probably not mush of a help,but my SP5(which is twin injectors),the Horizontal is 1 & 2 and the Vertical 3 & 4.
Old 04-Jun-2009, 21:31   #5
Thumbs up
cheers jasper,
it seems a harder question than i thought, but due to the limited number of replys ill go with #1 being the horizontal unless somebody else knows better.
cheers rob
Old 04-Jun-2009, 21:53   #6
Do you have a Haynes or Workshop manual that would tell you?
Old 04-Jun-2009, 22:19   #7
No!!
I downloaded the ducati manual and bought the 91 update and have spent the evening flicking through it trying to find any reference to it but to no avail.
As regards the Haynes manual, do they actually do one? As I’ve spent many-a-hour trawling eBay and I’ve never actually seen one on there.
cheers rob
Old 04-Jun-2009, 23:59   #8
paynep's Avatar
Mood: Wet wet wet
Just checked my '92 851 and 1 is indeed the horizontal cylinder.
Old 05-Jun-2009, 00:13   #9
Well its not too difficult, it will start, or it won't 50/50 chance
Old 22-Jun-2009, 21:12   #10
smilo006 smilo006 is offline
smilo006's Avatar
Mood: I like my bike
not the most stupid question ever. I was in the US and was looking to buy a hhhhhonda. I asked the bloke in the shop for a calculator. He said why, i said because I want to convert dollars into pounds. He asked how I was going to do that because pounds are measure of weight! Nuff said.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:09.
