Old 05-Jun-2009, 12:59   #1
Mello-Yellow Mello-Yellow is offline
Bikes: 848 EVO & Multi 1000ds
Mello-Yellow's Avatar
Mood: When's the sun coming out
Misfire, Stopped now won't start
Y reg 01 st2. On behalf of a mate. The bike misfired a couple of times then just stopped running. All the lights and dash lights are working. No noise from the fuel pump when the stand is put up,but can hear a click from a relay.Also there is nothing happening when the starter motor button is pressed.
I'm thinking it's either a fuse,relay or the stand switch is faulty, any ideas fella's.
Old 05-Jun-2009, 13:31   #2
keith888 keith888 is offline
keith888's Avatar
Mood: On the up
Sounds like you are on the right track. Dunno how the ST2 is wired but relays are certainly worth checking first. Try giving them a tap and/or swap them around and see what happens. If the side stand on the ST2 cuts both fuel pump and starter motor then that would also be a likely candidate.
Keith
Old 06-Jun-2009, 08:30   #3
Has the fuel filter been changed recently?If not,it could be blocked.
