Old 06-Jun-2009, 21:00   #1
eskimo eskimo is offline
eskimo's Avatar
Mood: sometimes
Bodge of the day
trying to make spacers for my rear wheel.
As when l was at the tyre fitters, he notice a big score mark in my swinging arm where the nuts of the sprocket had been grinding away the swinging arm
It must have been when l had the bearings done, must have lost the spacer on route
So i thought that l had all the bits, when l put it back together
Well for a master class in bodging, a guy at the tyre place found a piece of metal in a skip, that had the right size hole, so with the loan of a angle grinder and his vice, l ground it into shape, and l also needed another washer as a packer, they had one but the hole was to small so had to file this by hand to make it fit, but after about a hour of fettling, we had a perfect packing shims, job done
Now all l have to do is find someone who can weld alloy, to fill in the score make, as it has gone half way through the alloy
By the way l had perelli corsa 3's fitted, l think they should be the business Scrubbing in to be continued.
Old 06-Jun-2009, 23:13   #2
Depending how far dow south you are I usually get my Alloy welding done at Specialist welders in Steventon a few miles south of Abingdon
Old 07-Jun-2009, 09:58   #3
eskimo's Avatar
Mood: sometimes
Thanks for that, l will see whats locak first, Worthing area, anyone know someone?
I feel l should mention the tyre fitter, that was happy for me to use there tools and facilities for my bodge, they are Russ Tyres, http://www.russtyres.co.uk/ he knows his stuff when it come to tyres and he was the cheapest l could find
Old 07-Jun-2009, 11:48   #4
eskimo, your avtar looks like the guy at benson td last year...not you was it??
Old 07-Jun-2009, 11:57   #5
eskimo's Avatar
Mood: sometimes
No not me, the avatar is me at Brands a couple of years ago on my lardy FJR
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:39.
