Old 10-Jun-2009, 00:45   #1
MLC Racing MLC Racing is offline
MLC Racing's Avatar
Mood: Moto Guzzi are the new Ducati??
Thumbs up Clutch Springs
I would like to use stronger clutch springs in my 620 monster DD bike. It has the semi-slipper clutch thingy.
Is there a ducati spring from another model that I could use in a straight swap?
Old 10-Jun-2009, 03:26   #2
Chris Wood's Avatar
RS Springs will do the job nicely. Just dont tell everyone!!
Old 10-Jun-2009, 09:31   #3
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
Not in that clutch they won't, I've not found any that fit!
Old 10-Jun-2009, 10:02   #4
andys 900ss's Avatar
Hi Dave, me again.
We had that clutch in my bike originally but found it to slip. We put extra washers in to increase the tension on the springs but it then started slipping again so we tried to fit another washer in and ended up putting too much tension on and broke the clutch basket. So we ended up borrowing a clutch from Skids at Snetterton last year to get us through the meeting.
In the end we fitted an older non-slipper clutch and all was good.
Andy
Old 10-Jun-2009, 13:58   #5
paynep's Avatar
Mood: Wet wet wet
You have all got too much power.
I've done a season and a bit on my APTC clutch and it's only just started to grab on take off (see Snet race 2....), but no slipping.
Maybe it's because once I've got off the line I never pull the lever until the cooldown lap (or the graveltrap)??
I can't master the "slight slip to vary corner speed" technique, but maybe it only becomes necessary when you're fast?
Old 13-Jun-2009, 01:04   #6
MLC Racing's Avatar
Thumbs up thanks
So that'll be a no then!?
Is there room for an extra plate?
Old 13-Jun-2009, 10:35   #7
I remember using 996 ones in my first DD 620 - I think???? + an extra plate too...
Old 13-Jun-2009, 11:12   #8
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
You remember right.
I've put 996 springs in #34 to cure a bit of slip.
Old 13-Jun-2009, 14:16   #9
DSC Member AK AK is offline
AK's Avatar
dave quite honestly the std clutch with an extra plate in it and 916 type srpings is the way to go unless you put a full slipper in it. the aptc is a bit soft on launch and doesnt grip well and can lose you time at the start.
when we had to swap bikes last year between races after a big crash in race 1, clint went from 1st row to 13th at redgate purely down to the launch of the aptc clutch on the 2nd bike
Old 14-Jun-2009, 04:49   #10
Chris Wood's Avatar
Sorry, std clutch in mine with RS springs. 03'ssie
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:37.
