Old 10-Jun-2009, 17:33   #1
keith888 keith888 is offline
keith888's Avatar
Mood: On the up
Track day wet grip
I'm a bit curious about how modern radial tyres behave in the wet at track days. I've got Dablos currently fitted on the 888 with lots of tread left but have never ridden the bike on wet roads. Trouble is that also means I've never actually ridden any radial shod bike in the wet (my RG500 has crossplies). I know from experience that my reactions cope OK with the back stepping out on crosspiles but worry a bit that my reaction to chopping the throttle would produce a high side on a wet track. Is that the case as it is (apparently) in the dry? I'm interested to know what sort of feedback you get just in case I happen to do a trackday in the near future and we get some rain :-(
Keith
Old 10-Jun-2009, 17:41   #2
Diablos are good in the wet and tend to be very progressive as long as you're not too mental.
Anyway, IT'S NOT GOING TO BE WET!!!
___________^
Old 10-Jun-2009, 17:58   #3
Cadwell can be a bit slippery in places, especially round the mountain part of the circuit under the trees.
Go on the track walk with WJB as he'll explain it all to you!
Old 10-Jun-2009, 18:02   #4
andys 900ss's Avatar
Diablo's are good enough for 2.05 in the wet at Cadwell with only 61bhp
Andy
Old 10-Jun-2009, 20:44   #5
keith888's Avatar
Mood: On the up
Andy
Trouble is, to get that fast in the wet you need to be at the limits of grip. I'm sure that to get that fast that you generally have to end up exceeding the limits at some point which I would rather avoid :-) I don't have a set of track day fairings so I'd much rather keep a little bit in reserve! If the feedback from the tyre is good as Jools suggest then I'm sure I will be fine.
Fingers crossed its dry and I don't get to experience a wet track though I appreciate that it would be a good learning experience on the Ducati. I remember clearly the last wet track day I did at Cadwell. There was a small river across the start/finish straight on a drying track that I hit when WOT on the RG. I must have been banked slightly as the rear stepped out at what must have been >100 mph and the resultant moment nearly resulted in soiled leathers. The guy behind said he was thinking how impressive it looked just before he did the same thing!
Keith
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:55.
