Old 24-Jun-2009, 23:13   #1
adjusting rear brake..
just fitted some rear sets, see below picture
2 questions:
1) red arrow - should this bolt be tight?
2) green arrow - I have very little brake pedal before its on, and have to lift the pedal to get it back so its using all the travel, how can I adjust this out?
Last edited by bradders : 24-Jun-2009 at 23:22. Reason: fat fingers and lack of attention to detail!!
Old 24-Jun-2009, 23:53   #2
1- Yes
2 - undo the locknut on the pushrod, screw the pushrod into the linkage and lock it up. You're basically putting clearance between the pushrod and the head of the brake cylinder piston.
Old 25-Jun-2009, 00:22   #3
Originally Posted by nelly
1- Yes
thanks, I'll try that tomorrow.
Old 25-Jun-2009, 20:23   #4
fitting the return spring would have helped
all done now, cant wait to try them out - I've got a few mm of front tyre to scrub in!!
Old 25-Jun-2009, 22:41   #5
Ducatis have a rear brake
___________^
Old 26-Jun-2009, 00:14   #6
YMFB YMFB is offline
YMFB's Avatar
I just replaced my rear disc as it was so rusty it looked bad
Old 26-Jun-2009, 00:52   #7
am I alone in always havijng had a good rear brake on a dook?! without the return spring this baby was a one toe effort!
