Old 26-Jun-2009, 22:47   #1
Col996s Col996s is offline
Bikes: 996S
Col996s's Avatar
Tank protector
After getting a nasty scratch on my tank I am replacing my stick on plastic "Carbon" tank protector with a hard carbon fibre one shaped to the tank which will cover a bigger area.
What is the best way to stick it to the tank?
Old 27-Jun-2009, 00:20   #2
Silicon sealant worked best for me.
Spend some time making it fit first; use a hair dryer to heat the carbon so you soften it slightly and bend it to fit snug all round.
Old 27-Jun-2009, 01:42   #3
007 007 is offline
Bikes: 996 Bip
007's Avatar
Mood: CITIUS EST MELIUS!
I agree, apply some heat to the tank guard with a hair dyrer and use silicone sealant. Once bonded it will not budge!
Best of luck.
Old 27-Jun-2009, 08:17   #4
Bikes: 996S
Col996s's Avatar
Thanks guys.
I've no other use for a hair dryer these days so might as well make use of it for this.
Old 27-Jun-2009, 09:29   #5
Bikes: 996S
Col996s's Avatar
Searchs under the stairs......I know I've got a tube of silicone somewhere.
Good news I've found it, only a quater used.
Bad news I've left the lid off. I've now got one solid block of silicon. Drat!
Off to the shops.
Old 27-Jun-2009, 13:53   #6
Ha! Exactly the same thing happened to mine when I went to use it the other day. The lid was on but I think it was a few years old so it had all set. Mind you, I didn't realise until I'd nearly broken my fingers trying to pump it through!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:54.
