Old 03-Jul-2009, 17:53   #1
spinoli1 spinoli1 is offline
Bikes: 998Bip
Mood: Carbonara
748 - 998 Improved Cooling Query
Hi Guys,
Is anyone out there using a coolant additive/supplement with or in place of water/antifreeze on their 748 to 998?
My 998 runs plenty hot in this weather, and I would like to see a little reduction.
Any recommendations or tips?
Many thanks in advance.
Spin
Old 03-Jul-2009, 20:08   #2
Hot Stuff
One thing that's often overlooked on Ducati superbikes is that both oil and coolant radiator fin damage occurs from road debris. Without protection, the fins get bent over, air flow through the radiator is reduced, so coolant and oil temperatures rise over time.
After carefully straightening the bent fins, place aluminum window screening over the radiators to prevent future damage. Screen material with larger openings won't stop small pebbles. Don't worry, the inexpensive window screen material won't significantly reduce airflow. Do it on a new bike before damage occurs.
If you regularly experience high temperatures at speed, use WaterWetter, especially for track use (where it is usually mandated.)
WaterWetter is often used because it reduces the surface tension of water (the property that makes it bead-up) thereby improving further water's superior heat transfer ability while also adding the necessary lubricants and corrosion inhibitors. Lowering the cylinder head temperatures in a high compression race engine lowers the already-high fuel octane requirements. A WaterWetter/water mix has a slightly lower boiling point than a 50/50 glycol mix and alone provides no antifreeze protection. It can be used in combination with antifreeze.
Most important, WaterWetter will reduce coolant temperatures under all operating conditions. It's easy to see its advantage in modified engines having increased heat loads, and under high-load, high-rpm track conditions.
It's important to note, however, that for normal street riding in cooler and moderate weather it also can prevent the coolant from reaching optimum temperatures. Across-the-board temperature reductions of 15°F under all riding conditions are commonly experienced using WaterWetter.
Old 04-Jul-2009, 13:52   #3
Bikes: 998Bip
Mood: Carbonara
Thank you Shazam - WaterWetter ordered.
Spin
Old 04-Jul-2009, 16:29   #4
In the UK, water wetter is NOT allowed to be used in race bikes.
Reason is that it will leave a greasy/slippery coating the track if the bike is crashed and leaks water.
Old 04-Jul-2009, 21:04   #5
injected injected is offline
injected's Avatar
Mood: Blown away!
It's worth remembering that distilled water with no additives is a better coolant than a water and anti-freeze mix, so for summer you can just run water and benefit from better cooling.
Old 07-Jul-2009, 14:45   #6
Bikes: 998Bip
Mood: Carbonara
Thanks Guys.
Spin
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:16.
