Model Specific - Discussion, Technical Problems and Help
999 / 749
> termi gaskets ??
999 / 749
termi gaskets ??
05-Jul-2009, 15:07
Glyn
: st2......we can rebuild
termi gaskets ??
termi is blowing at the first joint from the rear cylinder. popped over to jhp and got this
http://www.ducatisportingclub.com/at...d=12467989 41
the one jhp have supplied is way to big anyway
took the exhaust off this morning and none of the joints have a gasket of any sort.
http://www.ducatisportingclub.com/at...d=12467991 11
should they have a gasket ??
Glyn
Send a personal message to Glyn
Find More Posts by Glyn
05-Jul-2009, 15:39
Ghost
: Ducati 749, Phil Read Replica, DD 620
: 2011 DD Class 'B' Champion
Yes all the joints should have a gasket, they are around £5 each, one large diameter and three the same smaller diameter.
Ghost
Send a personal message to Ghost
Find More Posts by Ghost
05-Jul-2009, 16:02
Glyn
thanks ghost
just to clarify this is the full 2 into 1 into2 54 mm system
Glyn
05-Jul-2009, 16:07
4
Ghost
My system is the asym one but a slip joint requires a seal regardless, or it will suck in air giving popping on the overrun and blow also.
Ghost
09-Jul-2009, 08:19
5
KeefyB
: Lurkin'.....
Did you get it sorted mate?
KeefyB
Send a personal message to KeefyB
Find More Posts by KeefyB
09-Jul-2009, 19:53
6
Glyn
yep all back together and no gaskets. just a bit of exhaust sealant.
Glyn
11-Jan-2010, 12:16
7
matty
my full system has no gaskets and no back firing???
matty
Send a personal message to matty
Find More Posts by matty
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:11.
