Old 09-Jul-2009, 12:10   #1
injected injected is offline
injected's Avatar
Mood: Blown away!
748 / 916 / 996 / 998 race parts for sale
All as removed from my beloved 996. Currently bike is complete and can be tested, but obviously as parts sell that will cease to be the case. Collection welcome, p&p extra or can deliver free to DD rounds. Will group items for discount.
Full 54mm stainless Termignoni system. Passes 105dB noise checks. SOLD
Marchesini 5-spoke wheels in original dark grey metallic coating with full-floating discs and serviceable Bridgestone wets SOLD
Large capacity Carbon Airbox, Vee-Two, standard air runner clips fitted SOLD
Carbon air runners, accept standard mounting clips SOLD
54mm Throttle bodies, Vee-Two SOLD
996 Engine, G-cams, corse rockers/springs, corse gearbox, MBP collets, Pistal hc pistons, lightweight flywheel, fully serviced last winter (incl all bearings) and only used at two trackdays since, dyno sheets. SOLD
STM Evo slipper clutch, new clutch plates fitted plus used spare set SOLD
Spare fuel tank, yellow, complete with pump etc no cap £175
Power Commander PC3 USB with Dave Woods map for above engine SOLD
Pair Marvic magnesium wheels, rear perfect, front slightly damaged but 100% straight and useable SOLD
Pair 5-spoke Marchesinis in black with good Racetech tyres, no discs SOLD
Showa TiN-coated forks, 65mm caliper mounting, good SOLD
Front discs, Brembo semi-floating, straight, pair £100
Four-pad calipers, Brembo, 65mm mounting, with new pads, pair SOLD
996S frame, 2001, with adjustable steering eccentric, powder coated red, straight, undamaged, no V5 £250
Adjustable fuel pressure regulator, straight swap for existing regulator under fuel tank, SOLD
Set of black race fairings, 998 style, with side stand cut out, upper, two sides, belly pan, black SOLD
Black fuel tank to match above with cap and pump etc SOLD
Black mono seat with nicely retrimmed standard seat, SOLD
Aluminium coolant header tank, mounts ahead of headstock so can be topped up without remioving tank and has sight glass for easy level checking, includes cap, hoses and nylon steering stops SOLD
Aluminium mono subframe, straight, for 1.6M ECU, slightly modified (modification can easily be reversed) SOLD
Race wiring harness for forward-mount 1.6M ECU, including carbon fibre headlamp bucket (repaired), modified to house ECU, c/w carbon fibre fairing mount ears £200
Techtronics Quickshifter, plug and play into Ducati wiring harness, switch built into shift lever (GP pattern), includes bypass toggle switch and all connectors for easy fitment £200
Single phase corse lightweight generator stator and rotor, stator new, rotor has been used £150
Renthal QC sprockets, all 520, all new and unused: 42, 43, 44, 45T £25 the lot
Renthal QC sprocket, 525, used but good cond, 38T £10
Standard size battery £20
QB Carbon swingarm protector, full length of swingarm plus guard for lower half of rear sprocket SOLD
Standard swingarm, good condition £50
Rear wheel eccentric, good undamaged cond, c/w bearings £50
Swingarm bearing set, new unused £50
998 rear brake caliper (silver) with pads £20
More to come, PM me for pics or call 07515-641889.
Old 09-Jul-2009, 14:53   #2
Mello-Yellow Mello-Yellow is offline
Bikes: 848 EVO & Multi 1000ds
Mello-Yellow's Avatar
Mood: When's the sun coming out
Hello,
Have you got a renthal sprocket carrier perchance.
Old 09-Jul-2009, 17:46   #3
injected's Avatar
Mood: Blown away!
Originally Posted by Mello-Yellow
Hello,
Yes! PM sent
Old 10-Jul-2009, 20:05   #4
injected's Avatar
Mood: Blown away!
Updated and reduced prices on unsold stuff.
Old 12-Jul-2009, 23:10   #5
injected's Avatar
Mood: Blown away!
More parts added, bike now fully disassembled
Old 14-Jul-2009, 18:53   #6
Gobert23 Gobert23 is offline
Gobert23's Avatar
Hi, I'm a Duc' newbie, but might be very interested in the front brake discs. Do you have picture(s)? So that I can check the pattern against the items I'm searching for.
G
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:03.
