Old 11-Jul-2009, 20:12   #1
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
swingarm hub and chain
Hello
I need some help, as I am not sure why this would happen.
Took the bike for a spin up the road, and the chain slowly became
very loose, so I undid the two main swingarm bolts and adjusted
the hub to tighten the chain. All ok then the same thing happened again.
I have checked the locking nut on the side of the swinging arm
(although I never removed it)
Something is not right, with the hub any ideas?
regards
TopiToo
Old 11-Jul-2009, 23:45   #2
It sounds like your eccentric hub is in the top 1-2 o'clock position instead of the correct lower 4-5 o'clock position. Both positions give the same chain freeplay but the torque-induced tension at the upper position tends to loosen the chain if the hub eccentric rotates.
Old 12-Jul-2009, 11:52   #3
PeteB PeteB is offline
PeteB's Avatar
Mood: ten, nine, eight oh bu**er lets go!
Steve, as Shazaam says; if it is in the wrong position I seem to recall that the caliper mounting bolts are more diificult to access.
Pete
Old 15-Jul-2009, 21:12   #4
Bikes: 748ish . .
Hello Shazaam/PeteB
Problem now fixed, it was indeed as Shazaam suggested,
Thankyou.
TopiToo
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:54.
