Old 29-Jul-2009, 09:58   #1
NEW Parts & Accessories for Sale
List of NEW parts/accessories currently for sale.
Will combine postage on multiple item - let me know if you want anything!
Billet Y-Spoke Clutch Cover
Billet clutch cover for all dry-clutch model Ducatis, called the "Y-Spoke" design as it incorporates the design of the Y-Spoke Marchesini wheels! These covers are 4mm thick - probably the thickest covers on the market to protect your clutch. Hard anodised in gold colour, not painted!
This clutch cover will fit all standard Ducati dry clutches, as fitted to 748, 916, 996, 998, 749, 999, 1098, 1198, Hypermotard, MultiStrada, Monsters, Supersports, etc.
£74.99 plus £3.95 postage
Billet Red Clutch Pressure Plate
This Clutch Pressure plate is made from Billet Aluminium and hard-anodised in "Ducati Red". It replaces your standard clutch pressure plate and can use the original springs and spring caps. It comes complete with a bearing fitted, so is ready to bling up your bike!
This clutch pressure plate will fit all standard Ducati dry clutches, as fitted to 748, 916, 996, 998, 749, 999, 1098, 1198, Hypermotard, MultiStrada, Monsters, Supersports, etc.
This pressure plate is not compatible with slipper clutches.
£64.99 plus £3.95 postage
Billet Race Shift Levers
This lever replaces the standard Road-Shift lever and rod linkage. Mounted directly to the gearbox output shaft, it gives you a "Race-Pattern" shift of 1-UP and 5-DOWN from neutral.
This gear lever will fit most modern Ducati engines, including 1198, 1098, 848, 999, 749, 998, 996, 916, 748, SuperSport, Monsters, etc. This will not fit machines which have shorter gear-shifters, such as the Hypermotard and Multistrada. Centre-to-Centre mounting of this lever is approx 110mm.
This lever is made from billet aluminium and hard-anodised in black or silver. The toe-peg is mounted on an eccentric cam so you can loosen the locking bolt and turn it round a full 360 deg, giving you an extra inch of setup positioning in all directions.
£34.99 plus £2.95 postage
Special Size Bi-Hex Sockets
Larger sockets can be hard to find, especially when they seem to be unqiue to Ducati wheel nuts! We sell only the best Chrome Vanadium finished Bi-Hex (12 point) sockets in sizes to suit most Ducati wheels. Sockets accept 3/4" ratchet drive. We also sell drive adapter kits.
£12.99 each plus £4.95 postage (cos they're heavy!)
Front Wheel Nut - 28mm
To suit older models including 748, 916, 996, 998, 749, 999, 620, 800, 900, 1000, 1100, Hypermotard, MultiStrada, S2R, S4, S4R, etc.
Front Wheel Nut - 30mm
To suit newer Superbike models including 1098, 1198 and Streetfighter.
Rear Wheel Nuts - Sprocket Side: 41mm, Wheel Side: 46mm
To suit older models including 748, 916, 996, 998, Hypermotard, MultiStrada, S2R, S4, S4R, etc.
Rear Wheel Nuts - Sprocket Side: 50mm, Wheel Side - 55mm
Socket Adapter Sets at £3.49 each. Pack includes the following 3 adapters:
1/4" to 3/8", 3/8" to 1/2", 1/2" to 3/4"
For example, use a 1/2" drive ratchet with a 3/4" socket.
Ducati Corse Red Polo Shirts
Sorry, sold out!
Brembo Caliper Brake Pins (R-Clips)
These Brake Pins (also known as R-Clips) are suitable for all Ducati / Brembo calipers that need replacement pins. Dimensions are 16mm x 1mm.
Sold as a pack of 6.
Handy to keep in the toolbox!
£1.49 per pack plus postage.
Ducati Relays - Fuel Injection, ECU, etc
Pack of 2 relays made by NAIS, as OEM fitted by Ducati to most models.
Part number ACM33221, suitable replacement for ACM13221 (functionally equivalent).
Great to carry as spares as they are known to go wrong.
£5.99 per pack plus £2.95 postage.
Old 29-Jul-2009, 09:58   #2
Brake pins and Relays:
Old 29-Jul-2009, 12:28   #3
gordonparker's Avatar
Ant, add some pins and an Xl polo to my cart !!
Old 29-Jul-2009, 12:31   #4
At this rate you'll qualify for more than a free T-Shirt...
http://www.avantiraceparts.co.uk/page.php?id=9
Old 29-Jul-2009, 12:35   #5
Does that mean I get the contents as well
Old 29-Jul-2009, 12:56   #6
Are you sure you could "handle" it in your condition?
Old 29-Jul-2009, 14:30   #7
Guido's Avatar
PM sent Anthony
Thanx, Guy
Old 29-Jul-2009, 20:15   #8
It's only the leg that's in plaster
All other areas are fully functional
You could also sell the via " Miss Wet T shirt" mag, I am sure one exists
Old 30-Jul-2009, 12:44   #9
kneedown kneedown is offline
Bikes: MONSTER S4R
kneedown's Avatar
hi will you be getting any smaller shirts cheers chris
Old 30-Jul-2009, 13:00   #10
Sorry, I only have Large and X-Large at the moment.
To be honest they've not been selling too well, even at nearly half price, so I doubt I'll order any more (as I have to order in bulk to get the discounts).
If you want a similar shirt, I'd have a look on ebay.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:16.
