Old 12-Aug-2009, 17:33   #1
madand71 madand71 is offline
slipper clutch on 996 makes nasty noises
its only on pull off when u have to let the clutch out it makes graunching noises especialy when hot , dose anyone no how to stop it making nasty noises many thanks andy
Old 12-Aug-2009, 18:41   #2
Murray Mint's Avatar
These clutches do need to be looked after, do you know when it was last serviced? Check the plates for wear. What make is the clutch?
Old 12-Aug-2009, 18:57   #3
it was fitted on the 30/3/09 it was ok for about a month then started making the noises then i took it back he did somethig to it it was ok for a week i rand him up and he said they make those noises lol im not sure off the make but i do know its the type that takes standard ducati plates
Old 12-Aug-2009, 19:54   #4
Mello-Yellow Mello-Yellow is offline
Bikes: 848 EVO & Multi 1000ds
Mello-Yellow's Avatar
Mood: When's the sun coming out
Most noise is caused by dirty plates or you need more dished plates in the clutch pack.
Do a search, loads of threads on this subject
Old 12-Aug-2009, 20:05   #5
whats the best thing to use to clean the plates many thanks andy
Old 12-Aug-2009, 20:34   #6
Brake cleaner i think has been mentioned in the past. You could do it the lazy way and give it a blast with a compresser if you have an open cover.
I take mine out turn them over and refit in a different position in the pack works well for a while.
Old 13-Aug-2009, 00:06   #7
Magpie Magpie is offline
Bikes: 749R
Mood: i'm in love... with cider at the moment
Originally Posted by Mello-Yellow
could do it the lazy way and give it a blast with a compressor
^^^worked for me everytime. i used an "air duster", air in an aerosol... grab it from maplin. bingo.
magpie.
Old 13-Aug-2009, 02:23   #8
ive got a compressor il try that and moving the pack thanks for the help cheers andy il let u know how i get on and il see if their a dished plate in the packt to many thanks andy
blowing it out with a compressor didnt work that well but striping the clutch and cleaning them with brake cleaner did and i did nitice their wasnt a domed plate i think it mentioned in another thread thanks for the help guys
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:14.
