Old 14-Aug-2009, 21:53   #1
rossco572 rossco572 is offline
rossco572's Avatar
Mood: elated
Question exhaust rebuild
as the first part of my exhaust system rebuild, i would like to remove the baffles etc from my standard cans, any got a link to a how to site as my searches have all been in vain! specifically would like to know how much of the perforated centre pipe to remove and do you lightly wrap on rebuild
Old 16-Aug-2009, 10:30   #2
dunlop0_1's Avatar
I have just done this mod on Louise's (mrsmonster) class B bike. It is easy enough to do but cutting off that lastt little bit of pipe took a while and lots of dremmel grinding discs. The bike sounds like a Ducati now but probably now power difference.
I did it working from inside the end of the can without taking the tube off which saved a lot of grinding and no welding back together.
I also cut a small V out of the inlet pipe bent it up and had it welded so the exhaust is more upswept.
http://www.ducatisuite.com/mufflers.html
Hope this helps.
Old 16-Aug-2009, 17:55   #3
Try this one Ross
http://www.ducatisuite.com/performancemods.html
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:37.
