Old 07-Jun-2004, 14:04   #1
180 or 190 profile on 6 inch rear rim?
What is the best tyre size to use on a 6 inch rear?
I'm looking to get some new wheels (c'mon Roy!!) and have a few part worn 180 rear SCs lying around that I'd like to continue using. (I think that Roy has been using 190s?)
Can I get away with these? Will it slow the turning a bit, or is this pretty much unnoticeable?
That's assuming that fitting a 180 to a 6 inch rim, will pull the tyre wider apart and effectively flatten its profile????
Ta
Tim
Old 07-Jun-2004, 14:11   #2
dickieducati's Avatar
i would have thought 190/55 would be the way to go.
Old 07-Jun-2004, 14:33   #3
Felix Felix is offline
I run Michelin Race 2 180 rear on a 6 inch rim without problems, even at race pace. Mind you it did spin up at around 140 down park straight!
Old 07-Jun-2004, 14:55   #4
psychlist's Avatar
Mood: Lucky? For some, maybe!
Like you say.....
I'm sure DJ uses 190's on his 6" rims.
I'll be reverting to 180's when I've worn out these OE 190 Pilot Sports.
Old 07-Jun-2004, 15:12   #5
Thanks for the responses.
I reckon I'll stick with the 180s and see how I get on then.
But she doesn't turn quick enough as it is!!!
I'm thinking of changing the steering angle - as adding too much rear ride height, gets the back end a bit too lively for my liking when getting on the gas early out of corners!!!
Tim
Old 07-Jun-2004, 15:59   #6
RickyX RickyX is offline
RickyX's Avatar
Tim,
I've run a 180 SC2 Supercorsa and then a RS2 Rennsport on my Mag Marchesini 6.0in rim...the turn in is noticeably quicker than the ol' 190 I previously used.
I was told that fitting a 180 to a 6in rim would have the effect that you mention (flattens the profile) but I thought I'd give it a whirl and, yea, I did it and it was good.
Give it a whirl...what's the worst thing that can happen............another muppet award????
Oh yes, I also run the steep head angle and have raised the rear...what's a bit of liveliness if it ain't a bit of fun???
Richard
[Edited on 7-6-2004 by RickyX]
Old 07-Jun-2004, 16:21   #7
DJ Tera DJ Tera is offline
The answer is.....
run a D208GPa Fatty
190/67/17
FWIW I ran bridgestone and pirelli 180 on the 6" rim and felt like total shite, but a D208Gpa 180 ran fine albeit spinning up out of druids - fun though!
190/55 renns/SCs are the most popular choice
Old 07-Jun-2004, 16:45   #8
Originally posted by RickyX
Tim,
no expert and not having a go at anyone so dont chuck me out of the club.
but i cant see how fitting a 180 on a 6inch rim will make the turn in quicker, it just cant.
the reason i would guess is that the 190 profile was 50 and the 180 profile was 55. ie a 'taller' tyre. even so when put on a 6 inch rim i would still feel there would be no quicker turn in compared to a 190 on a 5 inch rim. but i clearly wasnt on the bike and you were so clearly you have a better idea than me!
i still think a 190 55 would be better larger contact patch and a higher profile as well. win/win situation.
not sure if they do that tyre in road tyres but definitely in sc1/2 varients.
Old 07-Jun-2004, 17:01   #9
Ray Ray is offline
Ray's Avatar
DD,
I have seen that info. about a 190/55 being "the" choice but very few manufacturers do a tyre in that size. Maybe only Pirelli/metzeler and then only in a supercorsa??
Ray
Old 08-Jun-2004, 15:04   #10
RickyX's Avatar
Dickie,
You've really got me thinking now....
Here are some thoughts that I have currently:
- I have never had a 5in rim so I cannot comment about 190/50 on that size rim (I don't think it is recommended?)
- I was comparing a 190/50 on a 6in rim against a 180/55 on a 6in rim
- 190/50 tyre height is 190 x 50% = 95mm
- 180/55 tyre height is 180 x 55% = 99mm
- Perhaps the 4mm additional height of the 180/55 results in a tiny increase in head angle and results in a perceived quickening of the steering?
- Although a 180/55 is not recommended for fitment onto a 6in rim, the "spreading" of the tyre is only 0.25in per side. I would expect that this change in angle of the sidewall would not be transferred to the rolling profile of the tyre since the connection between the sidewall and rolling profile is "flexible" (in engineering terms, the angular deflection is not carried around the corner as there isn't 100% moment continuity at that joint)
- my comparison was conducted by comparing a worn 190/50 against a spanking new 180/55
- part of being in the club is that we are all allowed to have our own opinions, and those opinions stimulate healthy debate - so no need to worry about getting chucked out !
Richard
[Edited on 8-6-2004 by RickyX]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:58.
