Old 25-Aug-2009, 23:10
Mood: Come on spring!!!
F/S Pair of 748R 996R front discs. (Bigger offset ones)
I have a VGC pair of front brembo discs as fitted to the 748r 996r 998r bikes with the Ohlins forks i think they are the 15mm offsets. 6 Bolt pattern.
£150 + p&p, or can arrange a meet somewere along M62 as travel across it weekly
Old 29-Sep-2009, 13:44
jodycraw jodycraw is offline
Mood: good
Hi Chris,
After buying these discs from you, they are actually not the ones you describe them as. They are the standard 10mm offset, not the larger 15mm offset that the 748/996R etc take.
You seem to have been ignoring my emails and PM's - could you get in touch with me please, as I would like a refund.
You have my contact details already.
Old 30-Sep-2009, 12:37
henk155 henk155 is offline
what are those 10mm offset discs then used on?
and are they full floaters?
henk!!!
Old 30-Sep-2009, 12:40
The 996R had the standard offset, they will fit most Dukes with the 6 bolt fitting
Old 30-Sep-2009, 14:34
discs
Ive emailed jody and he will be sending them back after i get back from my working trip. So will be back up for sale as the standard offset disc. (10mm)
My apologies Jody my mistake
Old 30-Sep-2009, 15:25
Mood: good
Great thanks Chris, speak to you when you're back.
Old 30-Sep-2009, 16:50
khushy's Avatar
khushy khushy is offline
the "proper" 748RS and 99*RS . . .
discs are indeed 15mm offset - they cost a BOMB new and are only for the above "special" bikes and also fit the standard "road" wheels with a 6 bolt pattern.
I know - cause I have a pair on mine - VERY hard to find!
khushy
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:25.
