Old 07-Sep-2009, 15:15
pguenet pguenet is offline
FS - Magneti Marelli dash 748 / 916 / 996 / 998
Hi
Selling complete Magneti Marelli dash for Ducati 748 / 916 / 996 / 998 series.
This is a plug and play dash done by JHP / MM Competition.
The dash comes complete with:
- Dash with straight plug into the standard loom
- Fixing bracket
- Marelli strip of standard idiot lights (once again straight plug into standard loom)
- Mechanical to Digital converter for speed sensor
- Optional oil kit which measures oil pressure and oil temp.
- Set up Manual + Marelli box
Note 1 - the manual recommends to change the water sensor which I don't have. I would imagine that you would get this from MM Competition if you require.
Note 2 - the oil temperature would require to change the mesh filter for an air cooled one so the sensor can screw into it. Those are a straight swap as far as I know.
Note 3 - The CAN is currently closed but can be open to work with Marelli race ECUs, etc. For any upgrade MM Competition should be able to support you as they are a very useful bunch (they do the Nemesis ECU, etc)
Reason for sale is that I am putting a MXL Pista on my 998 instead which allows more configuration, data acquisition, etc.
I am looking for around £950 for this kit.
Please U2U me if interested.
Some pictures below.
philippe
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:20.
