Old 08-Jun-2004, 18:36   #1
wosser wosser is offline
Clutch help urgently required
Hi
Ime due at mallory tomorrow and have just changed the clutch on my 996SPS but have a snag. I have put the new clutch plates and metal plates back in exactly as they came out. The sequence was 2 metal the sintered/metal so in all 10 metal plates and 8 sintered. The problem after tightening up the springs the last plate is out of the basket and the clutch lever is rock solid, is it just a question of bleeding the clutch.
Many Thanks
Wosser
Old 08-Jun-2004, 18:43   #2
Jasper Jasper is offline
Jasper's Avatar
Have you lined the pressure plate up correctly with the clutch spring dowels?There is a mark on the pressure plate and a corresponding mark on the correct dowel.Make sure they are together.
Old 08-Jun-2004, 18:52   #3
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Whats the measurement from the face of the last plate to the face of the hub. Should be between 4-5mm. Also is it a slipper, if so do you know who's. Std plates will not fit STM clutchs. What is the overall pack thickness.
Old 08-Jun-2004, 19:24   #4
Thanks fellas all ok pressure plate was lined up properly roll on mallory
Wosser
Old 08-Jun-2004, 19:27   #5
moto748 moto748 is offline
And of course the clutch plate pack on the SPS is different from that on the standard models.
But I'm sure you knew that already.
The dished plates must be fitted the right way round (both different).
Old 08-Jun-2004, 19:29   #6
Jasper's Avatar
Was that "the pressure plate WAS or WASN'T lined up correctly?"If it was,what was the problem?
Old 08-Jun-2004, 19:59   #7
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
I read "wasn't".
Didn't know about lining them up though, will be looking out for that when mine are due for swap! Ta Jasper!
Old 08-Jun-2004, 23:07   #8
Sorry that was a typo the pressure plate wasnt lined up with the marks, but fine now btw the standard plates for a 996 £88.00 , SPS ones (sintered) £160.00 I suppose I could have shopped around but didnt have any time
Thanks again
Old 08-Jun-2004, 23:11   #9
Jasper's Avatar
Glad to be of help.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:14.
