Old 09-Jun-2004, 14:56   #1
m1keyp m1keyp is offline
BREMBO RADIAL MASTER CYLINDER
I am considering fitting a radial master cylinder.
Should I do it?
Will I notice the difference?
Am I right in thinking that the corect size is 19mm bore/20 ratio?
Where is the best place to buy it?
thanks
Old 09-Jun-2004, 15:07   #2
Jasper Jasper is offline
Jasper's Avatar
Yes,yes,yes and Nelly at Cornerspeed.
Old 09-Jun-2004, 16:19   #3
DJ Tera DJ Tera is offline
Don't go for the Brembo, it is way overpriced for what it is (cast, no brake switch etc)
http://www.redracingparts.com/en/pro...cyldiscacc.htm
CNC machined, brake light switch fitted (a brembo one is £30+ ) with flip-up levers to prevent them from snapping
And they are TUV approved as well
217 Euros, Thats about £150
[Edited on 9-6-2004 by DJ Tera]
Old 09-Jun-2004, 17:51   #4
Harv748 Harv748 is offline
Harv748's Avatar
ditto Jasper.
just bought and fitted one from Nelly. he also has the brake light pressure switches in stock.
Can be a little fiddly to fit. Very little clearance I found between the throttle assembly and the clip on part, where the MC will sit. I had to trim a little lug off the switch gear housing to get it to fit properly. No big deal, and not seen when fitted. Also the reservoir needs to be relocated.
I have fitted P4 calipers and SBK pads prior to fitting the MC and the total package is now eye-poppingly good...infact I would go as far as saying it would be a liablitly in the wet...and is probably over kill for the road..but it is nice to know the stopping power is there if I need it!!
For the track...its the dogs danglies
Old 09-Jun-2004, 21:45   #5
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
EVERYONE should do this. Fantastic peices of kit. Bad timing though..ive just flogged flanker a brand new DP superbike upgrade kit with all the gubbins included !!!
I would recommend the 19x18 version (as used by the hodgemeister!!!!) - nice feel.
Nat
Old 09-Jun-2004, 21:55   #6
Don't matter - Mikes listened to reason and sensibly gone for the Discacciati radial cylinders :P
Mine should be here by Monday too
Old 10-Jun-2004, 00:17   #7
Thanks for the replies!
Went for the DJ tera option but got sucked into the clutch MS aswell.
They replied to myorder in minutes so i will keep you informed.
Thanks again Mike
Old 10-Jun-2004, 14:53   #8
Mr_S Mr_S is offline
Mike, DJ
Which Discacciati did you order, and did you order anything else to help with fitting?
Old 10-Jun-2004, 15:55   #9
Just the m/cyl mate (19mm), it comes with a brake switch, and I was told to use the original brakeline and reservoir
Should be here by Monday - tax free too, gotta love the Italians!
[Edited on 10-6-2004 by DJ Tera]
Old 10-Jun-2004, 16:59   #10
Hi Mr_s
Fitting should be straight forward no other bits are required.
My handle bars are non standard (www.cyclecat.com ask for Alfred) fully adjustable height and angle but I do see a problem.
I will let you know when they arrive, i liked the fact that the brake switch was fitted and that the levers flip up
Mike
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:14.
