Old 21-Oct-2009, 13:28   #1
MSO 749s MSO 749s is offline
MSO 749s's Avatar
PC Remote Access
Afternoon All
Anyone out there use a program to remotely access their work PC? I currently use Hamachi to access files but need to see my Outlook so I guess a complete package where you see the desktop screen from elsewhere.
Hope that makes sense and would appreciate any recommendations.
Regards
Mark.
P.S. Can't wait for Sundays WSB...
Old 21-Oct-2009, 15:03   #2
http://www.tightvnc.com/
Run the vnc server on the remote machine you want to access.
Run the vnc client on the machine you want to use to log into the remote machine.
Easy peasy!
Old 21-Oct-2009, 15:14   #3
MSO 749s's Avatar
Many thanks Antonye, I'll give it a go tonight.
Old 21-Oct-2009, 21:06   #4
John W John W is offline
John W's Avatar
if your using WinCXP it has remote access built in. All you need to do is turn it on and then download the client.
These links tell you how:
http://www.microsoft.com/windowsXp/u...moteintro.mspx
http://www.pcadvisor.co.uk/news/index.cfm?newsid=10208
If you use Linux that coms with something called PuTTy. Its also available for Windoze as well. We use this extensively at work to access remote machines running linux from a winXp machine.
Old 21-Oct-2009, 22:05   #5
MSO 749s's Avatar
Thanks John but running Vista. Tried TightVNC tonight and works well, if a bit slow.
Old 21-Oct-2009, 22:10   #6
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Just use Remote Desktop that comes with Windows. You will need to configure your router or firewall to forward packets on port 3389 to the correct i/p address belonging to the pc you want to control.
Old 21-Oct-2009, 22:30   #7
jimbers45 jimbers45 is offline
jimbers45's Avatar
Mood: Faster!!!
go to my pc.....cloud based pay service.,,,,i found a little more reliable and faster than VNC
www.gotomypc.com
Old 21-Oct-2009, 23:24   #8
You can change the settings, eg more compression = faster.
Old 22-Oct-2009, 11:23   #9
phillc phillc is offline
Bikes: 996 race bike
Mood: Almost over it.
Why not just use SSH?
Or if you want a GUI, and using Gnome windows environment, Nautilus should work fine. Remote systems can be persistently mounted.
Not saying PuTTy is a bad tool (I use it when stuck with Windows), but Linux has other tools that don't require additional software. Although I appreciate your comment above was with regards to accessing a Linux box from a Windows machine.
Old 22-Oct-2009, 12:31   #10
You mean to say that none of you would recommend that flock of homing pigeons - even if you could train them to remember the keyboard?
___________^
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:42.
