Old 27-Oct-2009, 17:55   #1
Mood: Come on spring!!!
748-998 front discs, 10mm offset straight spoke
For sale pair of front discs from a 998. Which are 10mm offset and the newer design straight spokes. These will fit all bikes with the showa front end. (not ohlins)
£120 posted
Old 27-Oct-2009, 21:32   #2
powerwheelie powerwheelie is offline
why should these not fit Öhlins equipped bikes?
Old 27-Oct-2009, 21:35   #3
discs
Because they are 10mm offset, i believe Ohlins front ended bikes require 15mm offset discs!
Old 27-Oct-2009, 21:42   #4
Not all, several R models but I have a set of Ducati original fitment Ohlins here that use 10mm Offset discs, its easy to spot the difference in the two types of OE Ohlins forks, ones off the 748R, 998R etc have a 5mm step machined in to the the back of the caliper mount the others don't
Old 27-Oct-2009, 22:17   #5
discs
Thanks for that Kev, so may fit Ohlins forks also as above!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:59.
