Old 30-Oct-2009, 15:30   #1
Jasper Jasper is offline
Jasper's Avatar
FS:Narrow Track Race Discs
BREMBO 320MM NARROWTRACK FULLFLOATING DISCS
A superb pair of Brembo 320mm Full floating discs. These are in truly FANTASTIC condition.
There is no visible wear on carrier or rotors
These are genuine race discs and retail at over £400 EACH.
Ducati Factory superbike brake rotors. Composed of stainless steel with an aluminum carrier.
These are the same rotors used by all competitive factory race teams and will fit Honda, Suzuki, Ducati, Aprilia, Yamaha, Kawasaki. 320mm diameter with narrow pad area, for use with 2 piece billet calipers or Monobloc calipers.
Please check they will fit before buying.
Model Number: 08.6703.21
There is no wear on the buttons or the carriers-AS NEW
Rotors are unmarked with no deep scoring
·Rotors measure 6mm. Min wear is 5.5mm
·Carriers unmarked except odd stone chip
·Carrier center measures 80mm
·101.5mm PCD
·6 hole mounting
.10mm Offset
If you have ANY questions. Please Don’t hesitate to contact me.
£200
Old 30-Oct-2009, 19:44   #2
powerwheelie powerwheelie is offline
excuse my ignorance, you´re saying they just fit the RS bikes and not the normal road 916?
Old 30-Oct-2009, 21:00   #3
khushy khushy is offline
khushy's Avatar
these are race disks and NO they wont fit ANY road bike - they are for race bikes with 80mm mounting centers AND they will ONLY fit bikes with proper narrow-band/track calipers too - NOT the P4 type - the billet brembo type 2 or 1 piece!
khushy
PS - mode performance can probably, however, machine the correct carriers for your bike if you really have to have them!
Old 30-Oct-2009, 21:09   #4
Jasper's Avatar
Hi,
as Khushy says,these are specific race discs.they will fit other bikes as well as Ducati,but if you want them on a Duke you need the race wheel and calipers(or Radials as they can be spaced out if the disc size is incorrect).
Old 31-Oct-2009, 21:40   #5
Thanks for clarifying. I was unsure if they were the proper race discs or not, hence the question.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:38.
