Old 01-Nov-2009, 14:56   #1
spinoli1 spinoli1 is offline
Bikes: 998Bip
Mood: Carbonara
Regulator/Rectifier Wiring Help Please.
Hi Folks - 2002 998 Bip
There are 3 yellow wires that come out of the reg/rec, which lead to a block connector. The other side of the block connector has 3 yellow wires leaving the connector.
On my bike, this block connector caught fire and has melted away completely - spectacular, but not what you want on the way home on a Firday night.
I am going to replace the damaged wires and put in a replacement block connector.
The problem is I cannot identify which yellow wire (from the reg rec) should connect to which of the 3 yellow wires on the other side of the block connector.
Can anyone help me with this? Or does it not matter (any yellow wire to any yellow wire)?
I am an electrical moron, and would appreciate any advice.
Spin
BTW, once the wiring is sorted, I will set about establishing why it caught fire in the first place.
Old 01-Nov-2009, 15:01   #2
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Hello
maybe of some help
http://www.ducatisportingclub.com/sh...ad.php?t=78401
TopiToo
Old 01-Nov-2009, 16:00   #3
It doesn't matter, just make the new connection. Use some good quality terminals and coat with silicone grease.
Spin
Old 01-Nov-2009, 16:09   #4
Bikes: 998Bip
Mood: Carbonara
Thanks TopiToo.
Unfortunately, that thread doesn't answer my question - which yellow wire to which yellow wire.
Hopefully someone can answer this question.
Spin
Old 01-Nov-2009, 16:13   #5
Bikes: 998Bip
Mood: Carbonara
Whilst I was reading Shazam's article, Ghost posted the answer I am seeking.
Ghost - many thanks - Just to be absolutely sure (and before I do more damage because I have misunderstood your answer) are you saying that I can connect any of the reg/rec yellow wires to any of the yellow wires on the other side of the block connector?
Sorry to be pedantic, but really don't want another flamer.
Cheers,
Spin
Old 01-Nov-2009, 16:29   #6
Cheers,
Spin
Yes its safe to connect any yellow wire from the alternator to any yellow wire going to the regulator, they all have a AC voltage and as its not driving a motor the order in which they are connected doesn't matter
Old 01-Nov-2009, 19:52   #7
Bikes: 998Bip
Mood: Carbonara
Thanks guys!
Spin
Old 01-Nov-2009, 20:56   #8
Cheers Kev, saved my fingers.
Old 02-Nov-2009, 10:41   #9
MLC Racing MLC Racing is offline
MLC Racing's Avatar
Mood: Moto Guzzi are the new Ducati??
Question
I'd be interested to know what caused your electrical failure as the block connector on my DD bike has a certain charcoaly, crispyness about it!!
Old 02-Nov-2009, 13:05   #10
Pretty common. The connectors get dirty or corroded. This causes increased resistance across the terminals and manifests itself as heat. There can be some pretty high Amp'age across tehre and the heat melts the plastic connector and insulation. Snowballs from that as the resistance increases and eventually the assembly melts/fails.
Regular cleaning and electrolyte helps.
