Old 09-Nov-2009, 13:51   #1
indigoblue73 indigoblue73 is offline
indigoblue73's Avatar
Mood: Good
2008 S4RS Testrastretta Throttle cam fitment
Hi Guys,
I've bought one of these:
http://www.electraeon.com/throttlecam.html
but no instructions where shipped with the unit... Does anyone know how to fit one / has anyone fitted one of these before?
Cheers,
Martin
Old 09-Nov-2009, 14:01   #2
Originally Posted by indigoblue73
Hi Guys,
Cheers,
Martin
Why.....if your s4rs is the single cable type..........then your 67 degrees zero to hero!
i cant see any need for anything quicker....especially for the road!
if its the twin cable...try the R1 throttle grip £14!
Old 09-Nov-2009, 14:37   #3
Mood: Good
It's the 999 engined model... I previously had a 749 with a quick throttle grip (fitted at ProTwins) which was excellent. The monster's throttle twist travel seems to be huge!
Old 09-Nov-2009, 16:52   #4
Hi Guys,
Looks fairly straight forward.Just follow the throttle cable down to the inj throttle bodies,remove standard cam and fit new.Not sure if the spring will ping off when you remove the nut/bolt,so be carefull.
Oh yeah,as the blurb says,make sure you fit the new cam the right way round.
Old 09-Nov-2009, 18:43   #5
As ive said there are more simpler and cheaper ways to decrease the grip rotation........
Old 09-Nov-2009, 18:44   #6
I previously had a 749 with a quick throttle grip (fitted at ProTwins) which was excellent. !
..and not necessarily the cheapest option.........
Old 09-Nov-2009, 20:46   #7
Jasper Jasper is offline
Jasper's Avatar
I have fitted one to the 888.Brilliant.Just a straight swap for the original on mine,so i presume it will be the same for you.Be aware that the throttle cable will need adjusting.
It does make a difference-ask TP!!
Old 09-Nov-2009, 20:55   #8
007 007 is offline
Bikes: 996 Bip
007's Avatar
Mood: CITIUS EST MELIUS!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:10.
