Old 18-Jun-2004, 11:13   #1
m1keyp m1keyp is offline
REAR BRAKE KEEPS GOING SOFT
Does anyone have this problem?
The rear brake keeps going soft, requiring bleeding. it usually occurs after going down a steep slope (leaving a ferry was the last).
It was bled by Ducati at WDW2004 and is now soft again
Mike
Old 18-Jun-2004, 12:19   #2
Welcome to the most common problem of owning a 916-style Ducati
Old 18-Jun-2004, 12:29   #3
Steve M Steve M is offline
Steve M's Avatar
Mood: Sans moto
Maybe some viagra in the brake fluid will help
ok ok I'm going now
Old 18-Jun-2004, 12:43   #4
dickieducati's Avatar
must be using it too much
Old 18-Jun-2004, 13:26   #5
i wish i hadn't asked
Old 18-Jun-2004, 13:48   #6
I think it's just a common thing that nobody has managed to successfulyl crack yet - and if they have they're usually not sure what they did!
It must be down to a design fault in either the components used or the way they are positioned on the bike.
I had mine serviced a month or two back, and in the 12 mile ride home from TecMoto both the back brake had gone soft *and* the clutch fluid had started to go black.
Not that I'm bothered - I hardly use the back brake and, as Shazaam says, the clutch fluid going black doesn't make any difference.
Old 18-Jun-2004, 13:56   #7
MarkyMark76 MarkyMark76 is offline
Mood: .
My back brake is next to useless, which as Antonye says, i'm not that bothered about as i hardly use it.
Was a bit concerned about the black clutch fluid thing, but if that's another 'normal' feature of the duke then so be it!!
Old 18-Jun-2004, 14:22   #8
RickyX RickyX is offline
RickyX's Avatar
Mine the same...my solution is to bleed it once a year about a day before the MOT...
Old 18-Jun-2004, 15:19   #9
Mood: me in a mood? NEVER!
I stuck new pads in and dot 6 fluid and works for me every time no matter how hard I break with it. had to order the fluid but demon tweeks do it.
Old 18-Jun-2004, 15:32   #10
Thats right Ducati call it character!
