Old 09-Jan-2011, 11:47   #1
greggyboy greggyboy is offline
Spacers
Hi, i am fitting some 65mm calipers onto the front end of my ss, i have changed the forks, however the calipers do not quite sit centered over the discs, Do you need to fit a spacer between the fork and the caliper to line them up correctly.
Regards
Greg.
Old 09-Jan-2011, 14:17   #2
Regards
Greg.
Is the wheel exactly in the centre of the forks you may have to alter your axle spacers.
If the offset bias is to the outside of one caliper and the inside of the other then that would indicate wheel out of alignment in the fork.
Old 09-Jan-2011, 19:12   #3
I've never had any issues with alignment when chaning the forks and calipers at the same time. providing the wheel is centred
What front wheel and what discs are you using
Old 09-Jan-2011, 21:56   #4
Got to the bottom of the problem
The forks are off the 695 and they have an extra mounting type plate on that set up, so i will need spacers to compensate for this.
Old 09-Jan-2011, 23:28   #5
That suprises me Greg as my Monster 800 S2R came with two piston calipers, mounting plate and the smaller discs, but 320mm disc with 10mm offset (as found on most 996s, 916s, 748s, Monster 600/750/900, Supersports etc) along with 4-pot calipers bolted on without any alignment issues. And I though the 695 had the same original setup as my S2R
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:38.
