Old 18-Jan-2011, 20:57   #1
Swinz Swinz is offline
Bikes: Ducati 916, Yamaha Cafe Racer (Possibly)
Swinz's Avatar
Mood: About to start re-build and cafe racer project
Question 749/999 forks to 916
Hi
Does anyone know if i can fit 749/999 Ohlins forks to my 916, and if so, what would i need.
Old 18-Jan-2011, 21:03   #2
Originally Posted by Swinz
Hi
you just need the correct sized yokes to go with the forks the 999 ones will fit but obviously look different to say a later 748R that would then look like the 916 ones.......
the mudguard mounts are different and you also need to consider what your doing with your brakes.......offset and calliper mount........
Old 18-Jan-2011, 21:11   #3
As Andy says, yes they will fit with a few considerations.
Main thing will be the 56mm bottom Yoke.
Are you going with axial or radial caliper mount forks.
Disc offset i'm fairly sure is different, not a real problem if using axial calipers and the 916 wheel and discs but you will need 5mm spacers between the Calipers and the fork legs
Old 18-Jan-2011, 21:14   #4
ive actually got a 53 56 748r ohlins top and bottom yoke set sitting in my garage........
Old 18-Jan-2011, 21:25   #5
Andy your probably going to get a few PMs, emails etc now
Old 18-Jan-2011, 21:33   #6
well i kept them because of the ltd plaque on the top yoke.........when i fitted 30mm offset mag ones but hey im mercenary enough to sell..do you think they are rare then......he hee
Old 18-Jan-2011, 21:35   #7
Well more and more 748/916/996 owners are going to Ohlins forks these days especially for their trackbikes, so not so much rare as greater demand
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:16.
