Old 16-Feb-2011, 12:44   #1
tom.i tom.i is offline
FS: NEMESIS 2 ECU FOR DUCATI 998 etc.
A used Nemesis 2 type 3 ECU, with user manual & software CD. Does not include the cable to connect to a PC but this is available direct from MM Competition Systems or a global network of Nemesis authorised dealers.
Designed as a plug in replacement for the Ducati 998-998R, 1000SS 03-05, S4R 04-05, Paul Smart/SC 05, M-1000 04-05 bikes.
Nemesis is the worlds foremost 'plug in' replacement ECU for Ducati, offering unrivalled levels of user programmability. No more messy wiring alterations with 'piggy back' systems or putting up with emission controls that interfere with engine performance.
Nemesis offers 'plug 'n' play' replacement of the standard IAW5.9 ECU that is fitted to many Ducati motorcycles. There are a host of different maps to suit many different engine / exhaust combinations with many more under development. For those with a special project in mind of even if you want the ultimate map developing to suit your engine, there are many Nemesis dealers with dyno facilities and lambda equipment to take advantage of the mapping capabilities.
You can even develop your own maps using the map editor software or by linking up your own wide band lambda equipment and taking to the track. Nemesis is able to learn and correct itself for each cylinder.
For more information check out the manufacturer's website:
http://www.mmcompsys.com/products.php?pgid=137
£425 plus postage
Old 16-Feb-2011, 19:56   #2
Oh I could be tempted
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:13.
