Old 17-Feb-2011, 15:10   #1
ells ells is offline
ells's Avatar
One disc short of a pair
whoops
It appears my right hand brake disc is a tad warped. Seeing as I am down at Brands on Saturday I need to do something sharpish. Being a bit tight cash wise and limited mechanical skills the easiest safe solutuion is best currently. Apologies in advance for the numpty questions but
I am assuming that removing the offending disc, caliper and hose will make it very sharp on the brakes? This was my first choice if its not too harsh.
Can I remove the offending disk, caliper and hose, and fit 16 mm master cylinder reasonably easily? If I pick up a lever and reervoir will there be markings as to the size? How do I find out the size? I have a couple that I culd try but knowing my luck they wont be any better.
If I can find a replacement disc, how do I know its the right one? Are there different diameter discs, different hole patterns etc?
Does it matter if I get a left hand disc? (no s******ing at the back)
Thanks in advance for your wise words!
Mark
Current guess on the disc is a late monster disk and its a big round disc thing with no carrier (I think).
Old 17-Feb-2011, 15:31   #2
Jolley Jolley is offline
Bikes: 959
Jolley's Avatar
If I remember to bring my old Brembo discs you can throw those onto your bike for the test day.
Old 17-Feb-2011, 15:43   #3
ells's Avatar
Thanks Ron,
I am hoping to turn up ready to go (still got to put tyres on). That would be great if you could pack them. If I get sorted meanshilw will let you know.
Mark
Old 17-Feb-2011, 15:48   #4
Bikes: 959
Jolley's Avatar
Whereabout are you? They are in a box of bits in Aylesbury at the minute if you are nearby.
Old 17-Feb-2011, 19:31   #5
ells's Avatar
Thanks Ron,
after a quick phone call I think I should be ok now.
mark
Old 17-Feb-2011, 20:16   #6
I'll also have a spare disc if needed for the day...hopefully I'll be sticking 1 disc
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:38.
