Technical - Help or Info - NON Motorcycle
PC's, Internet etc. Cars, or how to fix that leaky radiator - in here please!
Old 09-Mar-2011, 22:26   #1
Lavras Lavras is offline
Problems With Slipper Clutch
I recently bought a Bucci Clutch on ebay
The clutch disks were not the same from the instructions, but since I have some spare clutch disks I used them to obtein the instrutions disks compilations.
The problem is that when starting to move the bike, in a low engine rotation, every thing is fine, but if I rev the engine to 3500 rpm or more, at firts every thing seams fine, but then the bike jumps a lot and squils - makes funny noises - (sometimes it iven stalls) and finally stops the jumps and rolls ok.
I tryed a lot of thing to try to stop this:
- i've sanded the iron disks
- I add another iron disk to obtein a 38mm thick group of disks
but It keaps doing the same.
Every thing else is ok. The slipper clutch is work well when I Reduce gears and while rolling, the clutch is smooth like it sould.
Please try to gide me trough this problem
Old 09-Mar-2011, 23:14   #2
Is the outer basket in good condition, It could be the drive (Fibre Plates) catching
Old 10-Mar-2011, 17:31   #3
Ducati Dealer JHP John JHP John is offline
Ducati Dealer
Thumbs up Bucci slipper clutch
Hello Lavras, you need to fit at least 2 new steel dished plates in the clutch pack and also there is a specific measurement required form the last clutch plate to the face of the clutch hub.
Give me a call tomorrow and I will explain what you need to do 02476335300
jhp john
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:09.
