Old 28-Mar-2011, 07:26   #1
Fastfasulli Fastfasulli is offline
620 oil leak from gear selector
Hi,
There is a weeping oil leak from gear selector does anyone know whether that could be a big job to sort out?
Franco
Old 28-Mar-2011, 09:56   #2
Originally Posted by Fastfasulli
Hi,
Franco
Prob just the seal that has hardened Franco, it can be done without removing the cover, but for ease and confidence it is best to remove. Then you can check the shaft diameter for damage that may have ripped the seal.
You will need to lean the bike over as there is a lot of oil in there. You can do it.
Once you have taken the old seal out use a socket to press the new one in.
