Old 04-Apr-2011, 10:42   #1
hawkati hawkati is offline
Bikes: ducati 996, hawkati, kawacati
hawkati's Avatar
Mood: generally vile and mischevious
Diameter of sssa hole?
er, as it says - a friend's plotting to get a sssa paddock stand and would like to know what diameter this is? cheers, jamess
Old 04-Apr-2011, 11:10   #2
If you stop posting in riddles, someone may be able to help you.
Old 04-Apr-2011, 11:34   #3
James Get yourself over to H-cafe this evening and tell us what it is your after as sssa doesn't relate to any Ducati I know of
Or is it code for Super Sport Swing Arm, can't be as its the wrong section
So must be Single Sided Swing Arm Hole in which case its about 26mm, probaly clearance size for a 25mm shaft to go into it, I measured the spindle as it was easier than digging out a paddock stand
Old 04-Apr-2011, 14:30   #4
hawkati's Avatar
cheers mr skidlids! sorry for confusion - i thought sssa was a universal acrnym for a single sided swingarm, so somewhat lazily typed that.....26 mm sounds just about right - will pass on info.
Old 12-Apr-2011, 11:42   #5
Gobert23 Gobert23 is offline
Gobert23's Avatar
Nope, not that I've ever heard anyways...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:25.
