DSC Website - Help and Notices
Information on using the site & requests for help or suggestions, as well as notices about site changes, updates and downtime.
Old 13-Apr-2011, 22:53   #1
aide998tt aide998tt is offline
Hi All,
When am using the search forum only the top 3 recent searches come up and the rest are from 2005 can someone help.
Thanks in advance
Aide
Old 13-Apr-2011, 23:41   #2
Looks like you've got some saved search preferences set!
At the bottom of the Search Forum screen there is a drop-down box that says "Save Search Preferences". Change this to "Clear Search Preferences" and then hit the "Go" button. That should reset everything.
Let us know if it worked or not!
Click image for larger version Name:	search.gif Views:	1698 Size:	15.3 KB ID:	12399
Old 14-Apr-2011, 00:03   #3
Hi Antonye,
I've change from save search preferences to clear seach preferences but its still the same.
Aide
Old 14-Apr-2011, 11:20   #4
icontest icontest is offline
icontest's Avatar
Hi Aide,
All the searches I've tried using an account the same as yours (this one) all return good results.
Can you let us know (by pm if needed) what search terms you are actually running?
Could be that there really are no results after the date you mention.
You could always try an advanced search from Google.com where you can point your search to the dsc website - as a crosscheck.
Cheers - Frank
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:38.
