Old 18-Apr-2011, 13:19
gh900's Avatar
gh900 gh900 is offline
Electrical idiocy
Hi
Hope someone can help. In a rush to get my 1995 900SS started last week, I connected jump leads from my car to the wrong battery terminals.
This blew the 15A fuse in the fuse box, and the big 30A fuse by the battery holder.
I took the battery out, topped up the cells which were very low, and recharged on the Optimiser for a few days. Armed with fresh fuses, I tried again at the weekend.
This time the 15A fuse blew, but not the 30A one, but more worryingly, a small puff of smoke came out of the switchgear by the starter button.
I read this thread: http://www.ducatisportingclub.com/sh...ad.php?t=12830 but I'm still not sure what I should try next.
Is it likely that the battery needs replacing as well as the regulator, plus checking for any melted insulation causing a short ? I don't have a multi- meter, so can't check the battery voltage either.
Any advice gratefully received.
Gareth
Old 19-Apr-2011, 10:11
Hi Gareth,
I see I replied on the thread link too - I think it covers most of the main points anyway.
I had to have a look at my fuse cover to remember what is what...
20A = Master
15A = 1) Ignition / Fuel pump 2) Hi & Lo Beam
You will need to get hold of a multimeter, Maplin do some good automotive types at reasonable prices.
The switch gear is very fragile at the best of times, I think the starter button uses the handle bar as an earth from memory but, like you, I think some insulation might have melted so have a detective job on your hands too.
Hopefully its mainly just regulator gone; £90 from...
http://www.electrexworld.co.uk/rr451...er-8310-0.html
guess you will have it already but quite a few good tips in the WSM, hope this link works for you:
http://dl.dropbox.com/u/26653469/Workshop_Manual_SS.pdf
Good luck - Frank
Old 19-Apr-2011, 11:21
FoxCorp's Avatar
FoxCorp FoxCorp is offline
Bikes: Tuono Factory - DD #58
Or you can get a new rectifier for £30 on ebay:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
Old 19-Apr-2011, 13:54
gh900's Avatar
Quick responses
Thanks for the replies - I'll post any progress here. Wish me luck !
I've got the WSM, so will have a read.
Gareth
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:51.
