Old 29-Apr-2011, 09:14   #1
tcat tcat is offline
Bikes: Ducati 748r-853r / SF 1098s
tcat's Avatar
Mood: ...much happier.
Talking 748r Seat Conversion - Expertise & Wisdom Required
Hi world
Looking for advice, preferably someone to walk-me through the conversion process to change my Monoposto into a BP Dual Seater.
Missus wasn't very happy when I said that the rear sub-frame was Ally as opposed to steel, therefore it couldn't take the weight. The condition of the buy was that she can have a go (rear pillion)... it made matters worse in the previous year when I bought her a set of leathers for her 30th - not good (not that the 30th present went down well anyway). My brownie points are quickly dissapating here - help!
So... I have to date purchased the following:
* rear BP subframe
* BP seat (no lights)
Appreciate if someone can advise if I need anything else? Looking to position myself to swap the seat in an instant, as opposed to spending ages exchanging seats.
* Unsure whether to buy the indicator rear lights as shown on flea-bay.
* Also I know that I need to buy a seat hinge
I did however, lift the rear seat and was surprised to see a mass of gadgetry...a little different to what was under my previous BP. Something tells me that a re-shuffle is required under here.
Any help or advice is grately appreciated.
Ash
Old 29-Apr-2011, 09:44   #2
Originally Posted by ashleyford
Hi world
* rear BP subframe
Ash
OK, it is an easy job, I have done it to my 748R as well, it takes around 10 to 15 minutes to change over the seat unit fron solo to bip.
Best bet is to have a complete bip seat unit ready to go, ie, front hinge, light unit fitted etc, and passenger foot rests.
A standard steel bip seat unit will fit straight on, the worst bit however is the electrics, this is due to the fact that the ecu sits 90 degrees different to the bip., I will put a few pics up later for you to have a look at the finished item.
Chris.
Old 29-Apr-2011, 11:20   #3
tcat's Avatar
Fantastic Chris, cheers fella... this is the main bit that is really worrying me, specifically the alterations to the ECU and where to screw it down to. I've just had a BikeTrac fitted and this is another lump that is clearly needs to be re-located.
Questions: did you manage to fit a tool tray after ECU positioning? It looks a little bit tight under her backside.
Old 29-Apr-2011, 13:53   #4
As promised, a few pics.
There is a pic of the original subframe, then 3 others which I have just taken showing the routing of the main cable around the alarm unit as it is longer than a bip wiring loom, tool tray does fit, the worst part I found was re- connecting the tail & indicator light connectors, this needs doing before you put the ecu back in.
Chris:burn;
Old 29-Apr-2011, 15:41   #5
Guido's Avatar
I agree with Chris Ashley, if you can afford to make a complete replacement seat unit (lights, brackets, hinges, wiring etc) it does make the whole job a damn sight easier. I can swap the seat from my 748R over to the BIP in about 5-10 mins now.
Old 30-Apr-2011, 20:56   #6
tcat's Avatar
Thanks for the pics. I will pick this up further on my next return to the UK... Just need to buy all the other bits + bobs in advance of my return
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:54.
