Old 03-Jun-2011, 17:48   #1
sheep911uk sheep911uk is offline
Fitting c/f airtubes and JHP filter
Have purchased c/f air tubes and a JHP filter anything i should look out for when fitting.
Complete Novice so even taking tank off will be a challenge !!!
Old 03-Jun-2011, 17:54   #2
Put something over/in the throttle bodies so you don't go dropping nuts / bolts / spanners down the barrels!!
Old 17-Jun-2011, 15:02   #3
Gobert23 Gobert23 is offline
Gobert23's Avatar
There's not much to it... a dead simple job if you just take a bit of time and care.
Just make sure that you've got the leading edge of the filter (front / towards the headstock) seated properly (it can be a lil' tricky) and you'll be fine.
Get some picture up, once you've got the job done as well, yes?
G
Old 18-Jun-2011, 13:01   #4
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Best way to fit the filter is to put your hand in the rear opening. This will help you locate the front opening onto the front bell mouth. Then as you withdraw your hand work the rear opening over the rear bellmouth and finally pulling down the rear edge with you hand now free. There should be instructions about oiling the filter supplied with it.
Have fun.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:16.
