Old 09-Jun-2011, 10:59   #1
PDL PDL is offline
Bikes: 803 rs race bike
PDL's Avatar
DD 583 rear bolt torque
What are the two rear spindle nuts torqued to, the 22mm ones? Been tightening them to a 'couple of big heaves', but would like to get it right, I have scoured the tinterweb and found the 900SS should be between 52 - 59 nm.
Old 09-Jun-2011, 15:14   #2
Not got my manual at home but tight as works for me
Old 09-Jun-2011, 17:20   #3
70 to 76 Nm for the 17mm axle.
Old 09-Jun-2011, 21:53   #4
I thought you had Matt Trayners old 600SS, which standard would have a Steel Swing arm and a spindle with a single nut.
If you have two nuts on the spindle then its either a 900SS spindle or a 600 Monster spindle, chances are if its the 900 Spindle then you probably have a Alloy swingarm
Old 09-Jun-2011, 22:57   #5
PDL PDL is offline
PDL's Avatar
Yes it is Matt's old bike, it also has an alloy swinging arm with two 22mm nuts so my guess is it must be a 900ss one then? i will stick to two heaves, and a grunt.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:21.
