General Motorcycles only
Old 21-Aug-2011, 22:43   #1
r15suk r15suk is offline
r15suk's Avatar
Spyball Alarm Issue
Hi,
Can anyone help with a problem that has cropped up on my Spyball alarm that is fitted to my 996.
The alarm is always in maintenance mode (so its not armed) and i never arm it.
Cleaned the bike and was just about to put it away and i heard a 'buzzing' sound coming from the unit. Turned the ignition on and it stopped (didn't try to start the bike as it was late and would have been antisocial!). Turned it off again and it started buzzing again. In the end i disconnected the battery to stop it, but i'll need to connect it up again sometime :-0
If water from the cleaning caused the issue then it may well do the same in the wet. I'll check later in the week when its fully dry what happens when i connect the battery again
Any ideas?
Simon
Old 27-Oct-2011, 00:56   #2
barksie barksie is offline
Hi
know its old post, but i just removed my spyball it more trouble than it worth, just re-soldered wires back in the loom, job done
steve
Old 27-Oct-2011, 00:59   #3
Originally Posted by barksie
Hi
steve
Yep best thing to do with the b***** things
Old 27-Oct-2011, 19:29   #4
chrisw chrisw is offline
Bikes: 999 Mono/1198S
chrisw's Avatar
Bin it! That's where mine is. Water ingress!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:09.
