Old 24-Aug-2011, 19:28   #1
Wanted M600 fuel pump
As the title says, anyone have a M600 fuel pump for sale ?
See if I can get to bottom of my bike woes.
Thx
Old 24-Aug-2011, 21:10   #2
Craig - it doesn't have one??? A few I think use R6 pumps. I have an SS tank with pump inside, if its usable your welcome to borrow to try
Old 24-Aug-2011, 21:31   #3
Craig I have a spare Vac operated fuel pump that you are welcome to try and I also have a R6 electric fuel pump somewhere
Old 24-Aug-2011, 21:49   #4
Ok, I think I mean Fuel Regulator then, In the parts cat its called pump. Will see if I can post up the diagram. Its No 16
16 0000.72924 Pompa benzina Fuel pump Pompe carburant Benzinpumpe Bomba gasolina 1
Old 24-Aug-2011, 21:56   #5
ells ells is offline
ells's Avatar
I think thats the vacuum operated fuel pump. theres a feed from one manifold to the pump, one from the fuel tank and then from there to the carbs.
My bike goes from the fuel filter to the carbs and has the vacuum pipe blanked off at the manifold. Removed said item as suspect.
Please wait for some one more technically minded than me to confirm this,
Mark
Old 24-Aug-2011, 22:06   #6
Thanks Kev, yes I'll give yours a go, quick swap over followed by a quick of whoop down the local road will reveal if thats the problem. If it is tempted to put a proper electric one on in its place if thats possible.
Mark, mine has had the fuel cock ripped out already as that was faulty.
Old 24-Aug-2011, 22:55   #7
Probably has half its inners stuck in the fuel pump
I have stripped vac pumps down before and cleaned them out
Will have to meet up so you can get it off me
fitting a 12V pump shouldn't be a problem no different to an SS running one, but just run it externally and don't worry about having a return to the tank
Old 25-Aug-2011, 06:26   #8
I have a fuel pressure regulator, it's on ebay at the moment.
http://www.ebay.co.uk/itm/2508782595...84.m1555.l2649
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:38.
