Old 26-Aug-2011, 08:51   #1
gixer620 gixer620 is offline
620i.e Sport Clutch Slipping High RPM
Hello all,
I have tried searching through the forums on the web since buying this little fun bag in April but can find people with same problem but never a conclusion on how it was sorted :-(
Anyway the story so far, collected bike gave it a good hand full to overtake got lots of revs and no traction to move forward bugger.#
Prob: - more so when hot (200+) but evident also from cold in the lower gears up to 3rd no evidence of slip will accelerate with no problem above 7-8K, once in 4th/ 5th then around 5-6K normally as I go to overtake something I get that lovely roar from the engine but a slow motion forward, this revs upward to 7K then catches up with itself.
So this is what I have done:
1. Bleed the hydralics - no real evidence of air or even bad fluid or too much or too little.
2. Dropped the oil & filter - removed the plates some signs of blueing on the steels, had the plate thickness and stack height checked by a Ducati dealer ( nice lads at Snells, Alton) all over height apparently.
3. New oil & filter Shell Advance fully synthetic by the book, also re-bleed the entire hydralics with Shell fluid.
Initial result no slip but not so long after as in less than 50 miles the good old slip returned and has been back ever since.
BTW the clutch is very light and I have to wind the adjuster screw on lever fully out to stop it slipping earlier.
Any help before I start to spend money on clutch springs etc,( any suggestions on springs appreciated).
Ian
Old 26-Aug-2011, 09:21   #2
If I remember correctly, a load of us running with fully synth oil had the same problems in DD racing. We switched to using Shell semi-synth and the problem went. It seems that fully synth is just too good!
Old 26-Aug-2011, 09:39   #3
Thanks for that have read many a post talking about the oil being the cause of the problem, I suppose it is not so bad to drop the oil back out and then replace with semi I actually have some Castrol GPS semi which I could use rather than spending more cash :-) On hols at the moment but will do my best to update with a conclusion if I get there.
Old 26-Aug-2011, 09:42   #4
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
Wrong oil mate stick some semi in & the problem will be solved
Old 26-Aug-2011, 10:31   #5
tbh, the shell fully synth has never given me any slippage problems, castrol and slikolene are the usual culprits..
When you say the matter is improved by unscrewing the detent in the lever improves things, are you running stock or pattern/aftermarket levers? These are usually the biggest culprit. especially the cheap pattern levers.
Try cracking the bleed nipple on the slave cylinder after pumping the lever a few times. If fluid comes out at anything more than a dribble, you could have a problem with the clutch hydraulics pumping up.
Old 26-Aug-2011, 17:40   #6
Stock lever as far as I could tell still have the araldite in it before I got to work on it in a vice.
Only thing not stock is the clutch master cylinder top cover has one from somewhere in the USA still has I assume the std rubber insert to stop the fluid sloshing around.
Once back in UK I will try the pump and bleed, if it does fire out then whats the next step in the diagnosis ?
Thanks for all comments guys more helpful than I received on other forums so far.
Old 26-Aug-2011, 22:26   #7
From one of my previous posts and the outcome was it worked fine and I'm still using the same setup in my current DD bike
http://www.ducatisportingclub.com/sh...ad.php?t=35525
As for the 620 Class A bike, it suffered from a immense amount of clutch slip at Cadwell as well as a small oil leak from the oil prewssure switch..
Off came the clutch casing, the switch was replaced and then the clutch plates were removed. All looked like new, there was no discolouration of the steel plates and all the friction plates were in a very healthy condition.
So I resorted to the same method of curing the slip as I did with the 750s clutch. Out came two of the stand steel plates and 3 of the standard springs to be replaced with 916 bits which again consisted of one dished steel plate (spring plate) one 2mm steel plate and 3 of the shorter but stiffer clutch springs.
I'll know if its done the trick when I take it out in practice at Pembrey.
Old 27-Aug-2011, 08:08   #8
I did find your post when I searched but I was then lost as too how I muster up all the parts to be able to do it.
The springs are cheap and easy, silly question but do you also need shorter bolts when you fit them ?
As for the 916 plates can you buy these separately from a dealer or is it a search fleabay for a some going begging ?
One question I had was can this be converted to a dry clutch style or is it really not worth the cost, also saw in the Haynes there were models with a kind of slipper clutch is this worth considering ?
I have yet to really get to grips with this little toy it feels like it is worth some effort to sort it out as when no slip it rides well all be it an Ugly duckling of the dukes.
Old 27-Aug-2011, 09:44   #9
I am sure Dunlop will be along shortly to chat about his conversion, his post regarding how it was done is here.
http://www.ducatisportingclub.com/sh...tch+conversion
Old 27-Aug-2011, 12:04   #10
No you use the same bolts as the spring top hats tighten down onto the top of the posts protruding from the clutch drum
You can by dished and 2mm plates seperately from Ducati Dealers, but most used clutch packs on Ebay should also contain then
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:20.
