Old 26-Aug-2011, 11:58   #1
tom.i tom.i is offline
Corsa race parts for sale 888 916R 996RS 998RS
I'm having a big clearout of assorted race parts.
All prices + postage.
Will post pictures as requested.
Any questions just PM me or email: tomirvine1 (at) mac.com
£185 Mil-spec Corsa fuel sender w/quick realease pump clip
£275 916R/996RS Corsa Marelli P8 Race ECU with billet housing cover
£625 Ohlins DU7270 ribbed corsa race shock, valved for long swingarm
£595 Ohlins DU7293 corsa race shock, valved for long swingarm
£595 Ohlins Factory ’98 shock as per Fogarty bike, valved for long swingarm
£1,550 magnesium long swingarm – refurbished, complete with billet alloy rocker
£1,500 original aluminium 955 corsa swingarm with original die cast rocker & ceramic mag hub
£250 748RS / 996RS twin-core water radiator, damaged/repaired good condition
£275 998S road frame, no chassis number
£525 MS Production ’96 955 corsa carbon airbox & air tubes (small area of damage to one of the airbox side panels)
£600 Marvic magnesium narrow-track race wheels 3.5 x 16.5 front, 6 x 16.5 rear
£315 Marchesini magnesium 5-spoke front wide track race wheel 3.5 x 17
£625 Marchesini magnesium 5-spoke wide track race wheels 3.5 x 16.5 / 6 x 16.5
£1,500 Marchesini 916 Racing (955 corsa) bright chromate magnesium wheels
£400 Factory 916 mil-spec loom – ex-Fogarty or Falappa, some cosmetic damge but working. For twin pick-up engine with four injectors.
£2,000 955 corsa engine, complete. Built by Pietro Gianesin (Frankie Chili engine tuner)
£2,000 955 corsa engine, built by Eraldo Ferracci USA
£175 955 corsa radiator, damaged but not leaking
£400 998RS MS Production carbon front fairing/dash support – new, never fitted
£200 MS Production 996RS carbon L/H side fairing panel used but not damaged
£950 MS Production ’97/’98 carbon corsa fuel tank, complete with pump & internals, fuel cap & frame mounting brackets
£225 tall carbon underseat breather box – manufacturer unknown
£140 996RS large oil cooler
£2,000 996RS Verlicchi TIG welded frame 2001
£1,200 996RS 2000/2001 full mil-spec wiring harness (3 pieces) used, good condition
£500 996RS Marelli datalogger box with sub loom to piggy-back off main loom
£150 pair of 996RS inlet manifolds
£1,000 998RS /F01 / F02 Weber Marelli IWF-1 injectors & loom – new
£275 Marelli P8 ECU with Ferracci 955 corsa eprom
£300 pair of Brembo 888 corsa fully-floating race discs (for small front hub) will also fit 916/996/998 road wheels
£220 pair of Brembo 320mm corsa fully-floating race discs for large hub
£250 Factory 916 Racing (1996/97) stainless steel upper coolant tank ex-Kocinski
£500 998RS ceramic magnesium large axle eccentric rear hub, complete
£750 original Weber Marelli 955 corsa 54mm throttle bodies
£400 Sicom 4-piston rear brake caliper – like Brembo
£200 Ohlins steering damper with factory billet aloy mounting clamp
£100 each 996RS 998RS mil-spec engine pickup (I have 3 available)
£100 996RS 998RS plastic upper coolant tank
£80 carbon corsa chainguard for long mag swingarm
£130 916R 996RS carbon dash / ECU support - new
£100 '95 '96 916 Racing corsa footrest jack-up plates (pair) - NEW!
£550 1998 916R / 955 mil-spec corsa wiring harness
£400 998RS / 996RS carbon front dash support (new!)
£150 Alloy monoposto rear subframe for P8 ECU
£160 916R 996RS L/H MS Production carbon airtube - new, never fitted!
£150 pair of 998RS slide-in carbon filters (slight damage - can be repaired)
£200 '96/'97 916R Factory wide track magnesium top yoke - bright chromate
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:19.
