Old 15-Oct-2011, 10:56   #1
nazgul nazgul is offline
Newbie
Bikes: Ducati sportclassic 1000S
slicks for 1000S wire wheels with inner tubes?
I was at Coventry Ducati yesterday discussing options for using my sportclassic 1000S for Thunderbike Racing. One of the things they didn't think was possible was using slick tyres with inner tubes on the 1000S wire wheels.
Does anyone know if it's possible to fit slicks to the wire wheels using inner tubes?
Old 15-Oct-2011, 11:15   #2
Cranker V2's Avatar
Mood: Green with envy
Tubeless tyres are used in supermoto and aprillia 450 racing wich used spoked tyres. SO ispokes and slicks can work, but not with an innertube. The tube and tyre would overheat with catostophic consequences me thinks
Old 15-Oct-2011, 15:51   #3
PDL PDL is offline
Bikes: 803 rs race bike
PDL's Avatar
I don't think ACU regs allow slicks for Thunderbikes. I may be wrong
Old 16-Oct-2011, 10:08   #4
With the low tyre pressures that Slicks use you would probably be in danger of ripping the valve out of the innertube as the tyre deflects as its worked to keep the heat in it.
Probably why you see a few Sports classics running 749/999 wheels which also allows the use of 4-pot and 4-pad calipers
Old 16-Oct-2011, 12:36   #5
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
Yes you can, nothing to do with ACU, It's the Thunderbike regs that you need to look at.
Old 16-Oct-2011, 19:19   #6
Bikes: 916 Strada
Chaz's Avatar
Done some research on this & it's not a good idea apparently,best to stick some ally's in, you should be able to sell your wire's ok, Rich at Louigi Moto was after some.
Old 16-Oct-2011, 21:04   #7
PDL PDL is offline
PDL's Avatar
Originally Posted by Chaz
...nothing to do with ACU...
What Chaz meant to say is if the Supplementary regs allow it then yes however the ACU regs states "unless stated otherwise in the supplementary regulations the use of slicks are not permitted at meetings of below national standard" so it depends what the Thunbike series Sup Regs state.
Nothing to do with the ACU isn't quite correct chief.
Paul #196
Old 16-Oct-2011, 21:34   #8
Bikes: 916 Strada
Chaz's Avatar
Paul #196
We used slicks in Thunderbikes for the last 2 years!!
Old 17-Oct-2011, 12:26   #9
Due Torri Moto Due Torri Moto is offline
Bikes: Ducati 916 Strada, 999 Biposto
Mood: Depends on amount of coffee
I am new to this site but thought that I would contribute to this thread.
An italian company called Alpina developed a system of sealing spokes on wire wheels originally for supermoto use; but they also make specific wheels for the Sport Classic range so tubeless tyres (slicks or otherwise) can be used.
They quote the combined weight saving to be 1.5Kg. I have also seen people in the States using these wheels with four piston callipers. So it can be done.
Old 17-Oct-2011, 12:45   #10
Bikes: 916 Strada
Chaz's Avatar
I was aware of Alpina also that the system wasn't very good on most wheels that's the reason for the specific wheels they sell.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:47.
