Old 31-Oct-2011, 14:48   #1
flatline flatline is offline
Bikes: Vtr1000 & 750ss DuCafe Racer. Leeds area
flatline's Avatar
Mood: Upbeat
Sprocket Carrier 750ss
Well, the bearings are out but the carrier is poorly
Can someone tell me which sprocket carriers I can use to replace it
I assume (hopefully) others will fit?
I have a J reg 750ss, registered in 92, the half faired model
There's a number on the carrier 16010041a
All help appreciated and if you have one for sale let me know
Regards
Old 31-Oct-2011, 15:07   #2
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
Regards
Think you will find all the SS ones will fit & the early monster with the hoop swinging arm.
Old 31-Oct-2011, 16:34   #3
flatline's Avatar
Mood: Upbeat
Crikey Chas,
You been waiting for this question
Thanks for such a quick reply m8
Regards
Old 31-Oct-2011, 21:07   #4
flatline's Avatar
Mood: Upbeat
Sorry m8
Chaz not Chas
Old 31-Oct-2011, 22:15   #5
paynep's Avatar
Mood: Wet wet wet
Just check that the sprocket offset is the same as there are two types that fit the early small spindle as fitted to 600/750/900 ss and Monster and the 851/888.............
Old 31-Oct-2011, 22:17   #6
Not most of the early monster ones as it has more of a sprocket offset just like the 900SS. There are some 600 Monster that did use the lesser offset one, year 2001 I think.
But otherwise 600SS/750SS/750SSie
And if you can't find one let us know as I can probably spare one
Old 15-Nov-2011, 15:48   #7
flatline's Avatar
Mood: Upbeat
May have found a sprocket carrier
Could someone tell me if this looks like the right model of sprocket carrier?
Mine appears to have a higher ridge round the bearing
http://www.ebay.co.uk/itm/320782642974?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2648
Old 15-Nov-2011, 21:17   #8
The carrier in the auction seems to have a similar part no. 1601004 but 2A!
How is the carrier poorly, exactly - the cush drives can be replaced but I remember reading its a time consuming job!
Old 15-Nov-2011, 22:05   #9
Yep, stay away from it, thats worn so much that its down for to the groove for the circlip that looks as if its gone missing.
I'll do you a carrier with bearing but without spacers or sprocket nuts for £25 posted if it helps you get sorted
Old 16-Nov-2011, 13:03   #10
flatline's Avatar
Mood: Upbeat
pm on its way
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:23.
