Closed Thread
Old 19-Nov-2011, 21:33   #1
tank weights/what forks
one for a sticky to add to DD info Kev?
or better still, how about an 'interchangable' sticky? Wheels, brakes, coils, swingarms, whatever...most of us have asked (or will ask) these questions
Old 02-Dec-2011, 17:21   #2
Working On it
Will sort out properly at a later date
M600 - Steel (No pump) 7.1kg inc filler cap
M620 - Plastic Tank + Pump = 6.9kg
600SS - Steel + 600SS Pump = 6.4kg
750 Sport - Steel + 600SS Pump = 5.4kg
916 - Steel + 916 Pump = 5.1kg
Alloy 851 Corsa (No pump) = 4.75kg inc filler cap
600SS - Alloy + 999 Pump = 4.2kg
955- 24L Alloy + 916 Pump = 4.0kg
955 - 17L Carbon + 916 Pump = 3.7kg
600SS - Alloy + 600SS Pump = 3.3kg
Old 02-Dec-2011, 20:08   #3
Class A are allowed adjustable Showa or Marzocchi forks from a OEM Ducati that fit in the standard yokes, these include the following
Monsters, STs and Supersports
M900, M900ie M1000ie, S4 and S4R, 1000S2R
then there are the ST2, ST3, ST4 and possiblty the ST4S,
along with 900SS, 900SSie, 1000SS
and possibly some of the sports classics,
Also the later 43mm forks are the same diameter tube as the superbikes so it should be possible to use parts from the superbike forks in the non adjustable forks.
I haven't done it myself but things to consider are the lengths
The Superbike Showa forks from a 748/916 are 715mm in length
The Non Adjustable 43mm Monster forks are 695mm in length
The Non Adjustable 43mm Supersport forks are 735mm in length
Using the Supersport forks for the conversion will reduce the amount of Suspension travel available by 20mm so springing will need to be set accordingly
Closed Thread
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:28.
